duck hunting boat??
Discussion in 'Boat Design' started by hoobilly, Nov 8, 2006.
  1. hoobilly
    hoobilly New Member
    can anybody help me out with some designs on a good flat bottom boat for duck huntin???:confused:
  2. lewisboats
    Likes: 128, Points: 0, Legacy Rep: 1603
    lewisboats Obsessed Member
    You want it to plane or row?
    Here's a rower I did up a year or so ago. Its about 12'2" long with a 4' beam. It has lots of flare to the sides, ala Dory, so you can haul the mutt over the side without swamping the boat. The depth of the boat is 15" (verticle) with 10" of freeboard at the lowest point at 540lbs gross wt. Using 2 sheets of 3/8" for the bottom and 2 sheets of 1/4" for the sides you're looking at around 100 lbs for the boat when completed. This could use a small (1-3 hp) motor for trolling speeds...or even a trolling motor. A planning version would be pretty easy to come up with.
    Steve
  3. lewisboats
    See...told you a planning version wouldn't take long :D :D !
    Steve
  4. hoobilly
    hoobilly New Member
    ha thanks it looks awesome.. will you send those two thubnails to me in an email please.. i'm having a hard time seeing them? thanks..
  5. lewisboats
    Click on them and you get a full page.
    Steve
  6. tja
    Likes: 1, Points: 18, Legacy Rep: 11
    tja Senior Member
    Tja
    google duck hunters boat page. There is a lot of info on the site of guys that have built there own duck hunting boat out of wood. Post your question on there talk forum and i'm sure you will get several responses.
  7. Cajun930
    Cajun930 New Member
    inboard or outboard motor?
  8. ted655
    Likes: 14, Points: 0, Legacy Rep: 122
    ted655 Senior Member
    Google "uncle Johns" boats
  9. Cajun930
    Cajun930 New Member
    lockport, La where mudboats are the regular means of transportation!!!!
