Dry sanding gel coat
Discussion in 'Fiberglass and Composite Boat Building' started by gages, Aug 9, 2015.
  1. gages
    gages Junior Member
    so I had to repair a hull of a boat I made , sanding down almost to the glass material , so needed to spray a new gelcoat layer over the hull and of course it needs sanding , can I dry sand say at 180/240 grit before I go too wet sanding to take the top of the gelcoat down a little ?
    Cheers
  2. ondarvr
    Likes: 532, Points: 113, Legacy Rep: 506
    ondarvr Senior Member
    Yes, just use what's needed to take it down, but you will need to removed those scratches so don't over do it. Doing it with a DA won't leave many scratches though.
  1. keith66
  2. Martin Upton
  3. scherzoja
  4. Weekend_Warrior
  5. bendisher2
  6. omamari
  7. afteryou
  8. MEJETSKI2000
  9. Frosty
  10. aaronhl
