richinname
New Member
- Joined
- Feb 5, 2025
- Posts
- Reaction score
- Location
- MURRAY, idaho
jet drives are about the only working solution for rivers/creeks.
A landing craft isn't the best solution for the ocean, but that is what is needed for off loading small vehicles, such as an ATV. Props are great for the ocean, but not for near the shore.
Outboard jet drives claim the solution, but how about efficiency?
So let's start with the boat...24' to 26 landing craft, aluminum, full cabin side to side located fairly
close to the stern. Some solar panels for charging batteries up top. Anchors for each end to load/
unload on the shore. UHMW on the bottom, forward to prevent wear by sand and rocks. Wheel
house raised above the cabin for viewing over the gate and to see river rocks. Controls so the
operator can run everything solo. 1500 pounds max. load except for fuel. I'd prefer to be able to
go 700 nm in 3 days on the ocean loaded (230nm/day). With a 12 hour day that's about 20nm/hr.
I'm guessing that the boat would have to be planing. If I fill with fuel twice on the trip, then I'm
guessing about 12 gallons per hour x 12 hours = 144 gallons, plus to make sure I'd have enough.
So, maybe 200 gallons of fuel. Dry boat weight is about 5800 pounds. I've been told that a
Hamilton 241 jet drive would be about the best drive. When I ran jet boats on the Salmon river in
Idaho, we used 460 c.i. engines. But that was about 45 years ago. We had problems with sand/silt
wearing the jet drives. As they wore, we would have to run the engines at higher RPMs.
