Drink cans,beer cans ETC,using as floatation
Discussion in 'Materials' started by djwkd, Sep 9, 2006.
  1. djwkd
    Likes: 2, Points: 18, Legacy Rep: 51
    djwkd Senior Member
    how tall are these?
  2. SamSam
    Likes: 200, Points: 63, Legacy Rep: 971
    SamSam Senior Member
    I get the idea whatever you are thinking about doing is not a good idea. You "want to make the cheapest ocean going raft you can get away with". Well, just add a couple more beer cans or a few more ping pong balls or a few more innertubes than the last person that died at sea had in their raft.
    You keep mentioning the F'ing Neutrinos. Try this place ...
    http://www.floatingneutrinos.com/Other Rafts/How to Build a Raft.html
    BTW, since the telegraph poles are all stacked now, it's not how tall they are, but how long they are, and that depends on whether they used Morse code in CAPITOL letters or small letters and also on how far the message had to go. Sam
  3. rturbett
    Likes: 4, Points: 28, Legacy Rep: 35
    rturbett Senior Member
    We have taken the saturated flotation foam out of old sunfish, and replaced it with sealed 2 litre plastic soda bottles with great success. That being said, we have never even taken a sunfish to the ocean!
  4. Ike
    Likes: 484, Points: 83, Legacy Rep: 1669
    Ike Senior Member
    I knew a guy who built a boat out of beer cans and fiberglass. First he emptied the cans (no I did not ask). Then set them end to end (I don't know how many) and rolled them up in fiberglass, soaked it with resin and let it dry. He made a lot of these beer can logs. He had built a male mold and formed the logs over the mold to make a hull. and of course stuck all the logs together to make it water tight. He left out the pigment so you could see the cans. I asked him to send me a photo but he never did. I wish he had.
  5. djwkd
    djwkd Senior Member
    sounds a good idea....
  6. djwkd
    djwkd Senior Member
    so..i could use a frame,floatation in...seal.....................??????????????????????????????????????????????????????????????????????????????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  7. Frosty
    Frosty Previous Member
    Yes absalutely. Could you draw some pictures of what you are trying to do.
  8. djwkd
    djwkd Senior Member
    i dont hve a scanner,also,will a)driftwood and B)drinks cans be ok and still float when sealed?
  9. djwkd
    djwkd Senior Member
    here they are,(mind you theres only one)in all its glory.
    here it is:as attachment.
  10. djwkd
    djwkd Senior Member
    Why wouldn't you want to take on ocean (although it is only going to be coastal)?
  11. Mikey
    Likes: 7, Points: 0, Legacy Rep: 75
    Mikey Senior Member
    true logic
    If it floats close to the coast, then it will float also when you go oceanic, no problems. It will just break up and sink faster out there. So you can bring less beer with you. Now let's see, assuming that you can collect empty beer cans for free and have to buy the ones that you want to drink, it's actually cheaper to build and run an oceanic beer can raft than a coastal one :)
  12. Mikey
    Mikey Senior Member
    design advice
    What a glorious attachment, yes, that will work. Forget the drift wood and fill it with sealed empty beer cans. Good that you live in Newcastle, plenty of free building material around.
    Are the cans of the light (alu) or the heavy type? Just thinking that the light ones would probably do well for a coastie but the oceanic model would probably benefit from the heaver and sturdier ones
  13. djwkd
    djwkd Senior Member
    I honestly couldn't tell you-and im sashamed to say i couldnt be bothered to check them all.I odnt know why everyone is assuming its just cans im using-im using 1&2 litre pop/soda bottles too!(and any other container that held a liquid and is sealed-cans are the only exception for the sealed thing).
    Anyway-they dont need to be sealed (i think)because there going inside a sealed frame of wood.
  14. Mikey
    Mikey Senior Member
    Regardless of if you are going to seal the frame or not, seal the cans. You'll be glad you did that when your sealed wooden frame isn't (completely) sealed any longer.
  15. alan white
    alan white Senior Member
    64 oz plastic bottles with caps would make more sense. Each one will displace 4 lbs of water. Here they would be 5 cents I think. Each one is seperately sealed, so it's a good idea security-wise. Aluminum will dissolve in salt water, I think.
    Packing peanuts (styrene foam) will fill any space, and are cheap or free.
    Flotation is cheap'n'easy except if you are building a proper little yacht like an H-12 1/2 or Haven 12 1/2, which specify a hand made copper air box, which is pretty foolish because it's cheaper to use foam and then buy a good used car with the change.
    A.
