Draining carbs, Suzuki DT 65
Discussion in 'Outboards' started by bchasc, Sep 16, 2018.
  1. bchasc
    bchasc New Member
    Greetings,
    I would like to ask how to drain carbs on a DT65. Engine is oil injected. I've scoured the web and can not find the answer. Hoping one of you experts will help. I believe there is a small screw and washer on each carb used to drain. Is that correct?
    Thank you for any help you can give.
    Thank you,
    Bruce
  2. Mr Efficiency
    Likes: 1,036, Points: 113, Legacy Rep: 702
    You really need a workshop manual for that engine, I don't know how wise it would be to download something off the net, some sites might be dodgy, but failing that, should be available in print. I googled "workshop manual Suzuki dt 65" and plenty came up, though I'd be choosing carefully, and probably not something with ads plastered all over it.
  3. bchasc
    bchasc New Member
    Thank you for the help. Time to get a real shop manual.
    To you and yours, down under.
    Bruce
