drag coefficients of an oyster barge
Discussion in 'Hydrodynamics and Aerodynamics' started by arn0, Nov 23, 2015.
  1. arn0
    Likes: 1, Points: 0, Legacy Rep: 24
    arn0 Junior Member
    Hello,
    I am looking to estimate the wave, form and viscous drags of a typical aluminium oyster barge.
    Those workboats are very common in France under the name "Chaland":
    http://www.navalu.fr/chalands-ostreicoles-aluminium
    typical lenght 12m & beam 3.5m.
    I guess they are actually planning when empty, but I am particularly interesed in low froude numbers, around 0,20 and 0,30.
    Would one of you have some data on those type of hulls ?
    Thank you very much,
    Arnaud
  2. daiquiri
  3. arn0
    arn0 Junior Member
    you're my hero
    Thanks so much, this is an amazing paper, I learnt a lot!
    it took me quite long to read it, since i didn't have the vocabulary, and too bad it is not in the metric system - nobody's perfect :p
    But i guess I understood most of it.
    Some differences I see with the oyster barge:
    - this study is ultra well documented on the effect of hull shapes on drag and stability of towed or pushed barges at Froude < .2 (with most of the study at froude .1), Lwl > 100 feet, B/T between 2 and 3.
    - where the oyster barge is self powered, more in the Froude between .2 and .3 (when loaded, because I guess they can actually plan when empty, can someone confirm ?), with LWL = 40 feet, and B/T around 10 with L/B around 3.
    I guess that :
    - the pushed or towed vs selfpowered only affects stability (but maybe it changes the apparent LWL ?)
    - the LWL>100feet doesn't change so much (only used in the "froude friction coefficient" page 18, which should be around 0,009 for 40 feet).
    - it seems hazardous to extrapolate the Rr/froude curves (fig 7 page 14) to froude 0.3.
    Thanks again!
    Arnaud
  1. Greg Oosterbaan
  2. Heimfried
  3. Erwan
  4. andrew spiteri
  5. Solario
  6. Alan Cattelliot
  7. mitch184
  8. maughanjamesr@gmail. com
  9. bitfield
  10. Bishiba
