jesdreamer
Junior Member
- Joined
- Jan 17, 2013
- Messages
- 88
- Reaction score
- Location
- Alabama
Could it be that a deep draft hull might require more power than a hull of similar displacement but more wetted area and thus less draft -- I realize friction at lower speed ranges should be greater but I am talking of wavemaking resistance. It seems to me that pushing the water out of the way from a lower draft hull would take less power than from a deeper draft hull of similar displacement. I realize the total work (as defined by force and distance) might be theoretically the same but I can't get over the idea of less distance to move each element of water perhaps being more important and that the lower draft hull might take less power for similar speed -- Could time be a critical factor here?? The work to move "x" elements of water a longer distance might be similar to the work to move more elements a shorter distance but since power is work within a specific time, it would seem to me that the water displacement would have to move faster in the deep draft case to accomplish the same volume displacement within the same time and therefore require more power even though "work" in the 2 cases would be similar -- Any thoughts on the subject??
