dory catamaran hull
Discussion in 'Multihulls' started by frank smith, Feb 2, 2010.
  1. frank smith
    Likes: 14, Points: 28, Legacy Rep: 185
    frank smith Senior Member
    In looking at catamaran hulls i see many different ways to go about their design.
    I am interested in a simple dory hull form and wonder what the disadvantages of the hull form are.
    I must have info right away for great project to be built in India .
    Thanks Frank
  2. bill broome
    Likes: 2, Points: 0, Legacy Rep: 48
    bill broome Senior Member
    dory hull.
    have a look at richard woods' site, he offers a 22' dory hull boat design.
    they work just fine, and are relatively easy to build. if you must have a catamaran, his designs are good.
    but in the 6-8m range, there is a lot to be said for a trimaran: the bigger main hull is more human-sized, and they are easier to put on and off a trailer.
  3. frank smith
    Thank bill , I'll check that out .
  4. guzzis3
    Likes: 65, Points: 28, Legacy Rep: 42
    guzzis3 Senior Member
    Waller has a range of "truncated V" hulls, essentially dories. The coral coast 25 is a very nice trailerable ocean capable design.
    The dory is simple to build, not as fast as more complex shapes so not the best choice for a racer, but for cruisers they are a good choice.
    Richard Woods has done a version of Gypsy without the cuddy and demountable for some clients. 28' with 6' headroom.
  5. rayaldridge
    Likes: 26, Points: 0, Legacy Rep: 322
    rayaldridge Senior Member
    Here's a dory cat that I like a lot:
    I think the hullform has a lot of advantages, and fewer disadvantages than it might appear. It's easy to build, it makes for a dry boat, and it sits on a trailer or the mud flats with much less stress than a boat with rounded bottom.
    Disadvantages might include more turbulence from the chine, but my opinion (and not just mine) is that the long slender hulls of multis develop less turbulence from chines than do the fatter hulls of monohulls.
    The most interesting thing I've learned from sailing Slider is that she goes to windward fairly well even without her big daggerboard. I'd hesitate to ascribe this to her dory hulls, but as a data point, Bernd Kohler has had good luck with these hull forms (and what he calls "anti-vortex" horizontal fins.) Anyway, the whole thing intrigued me enough that I'm building a simple little cartop cat as a test platform-- to see how well a dory cat can sail to windward without conventional boards.
  6. frank smith
    Ray, I have seen pictures of your cat on the web. Nice job .
    The cat I have been thinking about would be a glorified pontoon boat that would carry small house about 20'X 10' , but I dont think that the displacement can be made large enough .
  7. rayaldridge
    Frank, what sort of displacement are you talking about? Is this boat to be powered by an outboard or by sails?
  8. frank smith
    It would be a power boat , not fast ,12kn would be ok . Disp. looks to be about 8000lb
  9. rayaldridge
    Frank, just for fun, I blew up the hull I'm currently drawing to 34 feet and a cat built of those hulls can handle 8000 lbs. The hulls would still be 12 to 1, so a relatively small outboard ought to be able to push them along without a lot of fuss. Of course, these are sailboat hulls, not powerboat hulls, but the point is that dory hulls can carry a surprising amount of displacement. That's one reason I chose them for my 16' beach cruiser. Using another chine to approximate a semi-circular section would have lowered my displacement significantly, though the boat would probably have been a little faster.
  10. guzzis3
    Ray, damian here, we have corresponded on yahoo and other places.
    Frank, the dory has a slightly larger wetterd surface area than a rounded hull. This matters little and the chine turbulence matters not at all on a power boat. It's a good choice.
  11. trev0006
    trev0006 New Member
    This looks gorgeous.
  12. rayaldridge
    Thanks. It's a pretty place, at the east end of Perdido Key, just south of Pensacola. It's really only accessible by boat, since the eastern end of the Key is National Seashore. At night, facing the Gulf, you can't see the loom of Pensacola's lights, and the sounds are surf breaking on the Key and the clang of the bell buoys that mark Pensacola Pass.
    I wrote about that trip here:
    http://slidercat.com/blog/wordpress/?p=64
    http://slidercat.com/blog/wordpress/?p=72
    http://slidercat.com/blog/wordpress/?p=73
    And a little video I shot when leaving that beach:
    http://www.youtube.com/watch?v=VHjY5RKyTbQ&feature=user
  13. Chris Ostlind
    Chris Ostlind Previous Member
    Just curious, Damian.... I know of the wetted surface issues, but how do you come to the following conclusions?
    Would not all forms of drag have an effect on the performance/efficiency of an immersed hull. Wouldn't the added drag signature demand more fuel usage and/or a larger engine?
    It would seem that if one were shooting for a high efficiency design, for instance, that all of these issues would jump straight to the top of the list.
  14. Guest625101138
    Chris
    There is negligible difference between a round chine and squarish hard chine from a drag perspective at displacement speed. As the speed goes up the better lift of the flat sections on the hard chine usually reduces drag compared with the round chine.
    The hard chine will have smaller max Bwl for the same displacement and length. This lowers wave drag and more or less offsets the slight increase in wetted surface.
    There will be unique aspects to each case but generally there is very little difference in drag between round or square chines.
    Rick W
  15. Chris Ostlind
    Depending upon actual hull shape, boat weight, etc. and the potential angle of attack to gain significant lift.
    The unique aspects would seem to be far more than unique when it comes to a preference in hull shape for efficient, power cruising designs. Just casting about in the fleet of boats about the same size and purpose, you do see flat bottomed power cats, every once in awhile. They are not typically meant for displacement speed motoring. All of the really good displacement and semi-displacement power cats of this size and smaller, are more in the rounded chine environment, if not outright smooth hulled, much like those seen on a Tornado cat. This is especially true for the boats that are aimed at good, semi-displacement speeds and minimum engines.
    Now, if the argument is ease of build, especially with commonly available materials then there are a whole bunch of new considerations and dory-esque designs start to make some sense. Others may jump-in here with their favorite build technique, so that discussion is pending.
    Drawing upon the conversations I have had with Kurt Hughes, who has a considerable amount of experience with boats of this type; His suggestions are, if it's in the 30 feet LOA range, then the Tornado style hulls make the most sense. I'm seeing power cats with all kinds of different hull strategies above that size. A leisurely cruise through all the obvious designers will show a wide range of hull solutions that are supported by customer feedback and endorsements.
