Does cutout on transome of this "cruser/racer" make sense or no?
Discussion in 'Sailboats' started by Squidly-Diddly, Jun 18, 2013.
  1. Squidly-Diddly
    Likes: 169, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
  2. jehardiman
    Likes: 1,077, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Open transoms were originaly to save weight and help freeing, but seeing where that rudderpost is, I'm not so sure about this DIY. Looks like at least winch handles are at risk....Thunk...skitter...splash...followed quickly by "Damne!"...
    Here is an unmodded Serendipity 43
  3. rwatson
    Likes: 477, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    It makes entry to the water a bit easier, you could launch and retrieve two kayaks very easily.
    If the purpose is to make getting huge bow waves out of the cockpit quickly, it needs to have some sort of 'strainer' to separate bodies and gear from the seawater before it goes overboard. Maybe there is a net thing on the boat for this purpose.
  4. messabout
    Likes: 482, Points: 83, Legacy Rep: 1279
    messabout Senior Member
    That is not an unusual feature on sailing dinghys. The little boats usually have a gasketed door that hinges in such a way as to drain the innards of the boat while underway. The door is usually held shut by a cleated line or sometimes a bungee. The door is allowed to open as necessary but is otherwise kept closed. The doors are often made of Lexan or Plexi so that the skipper can see the condition of water exit at the transom/waterline intersection.
    That is a useful feature on a dinghy. On this boat, the door would be pretty big and the swim ladder would interfere. All out racer boats with open transoms are apt to get the crew wet but the water will exit as soon as it comes aboard (along with winch handles and sandwich containers of course)
