Does a hull need to be specially designed for surface drive.
Discussion in 'Surface Drives' started by tom kane, Aug 4, 2015.
  1. tom kane
    Likes: 51, Points: 58, Legacy Rep: 389
    tom kane Senior Member
    Some say any boat hull is suitable for surface drive, some say a hull should be designed to suit a surface drive.
    From long-tail drive for canoes to fast ferries does hull design matter?
  2. PAR
    The short answer is no. The long answer is it depends on what you want.
    DogCavalry and sandhammaren05 like this.
  3. tom kane
    The boat on the left could probably termed a displacement boat with that deep V and the surface of the water would be very deep and only when the boat moves forward.
    Quite a lot of dragging appendages on image 2 loosing benefit of surface drive.
    Image 3 props would need to be dropped to a very steep angle to gain any thrust.
  4. PAR
    The boat on the left doesn't appear to be a displacement boat. Surface drives can be used in slow moving applications, though a costly way to get propulsion. Who know what they're trying to do in image two, but speed or efficency isn't very high up the list. The right most image seems a reasonable arrangement for rakers.
  5. powerabout
    powerabout Senior Member
    If a boat was optimised for sterndrives you are going to get a different result with surface drives as they cant do the same job
  6. Mr Efficiency
    I'm amazed Tom thinks the boat on the left is some kind of displacement hull. It appears to be a deep-V planing hull of around 24-25 degrees deadrise angle.
  7. PAR
    Surface drives can perform the same role as outdrives, but the speed range will change, with possable hull mods being necessary, to address some condisional issues.
  8. powerabout
    and the first day you are in a tight marina with the wind blowing you will wish you had your sterndrives back
  9. tom kane
    what I think does not really matter we have expert guidance for free everywhere.
  10. tom kane
    Optimizing a hull for stern drives surely means the hull is specially designed for stern drives.
  11. tom kane
    Number 2 image is a micro-hull,so I suppose there is a little artistic leeway allowed.
  12. tom kane
    Not if you have retractable and adjustable propeller operating depth.
    If you have expensive surface drives you probably can afford bow thrusters and other bells and whistles,
  13. Ad Hoc
    Well, it makes a big difference if your cut-n-paste expert does not even know the difference between a "ton" and a "tonne".
    Hardly inspires confidence...but hey it's free, so you seem to be happy :p
    DogCavalry likes this.
  14. tom kane
    The difference between a "ton" and a 'tonne" is just a measure and is not relevant,
    the definition remains the same in any language.
  15. Ad Hoc
    For someone that is constantly seeking clear/exact explanations of hydrodynamics etc that you are unaware off, whereas others are (and still dismiss them), thus always wanting the replies to be of an clear/exact nature - so YOU can understand the reply - to define your question 'correctly, as you see it, that is a very lax and lame reply! Definitions are everything in engineering..
