Paddlelite
Junior Member
- Joined
- Feb 3, 2013
- Messages
- 35
- Reaction score
- Location
- Maryland
I’ve been playing around with an easy, on-water means of comparing the efficiency of human-powered craft (canoes, kayaks, and paddleboards) which operate in a narrow speed range. With about 10 seconds of high-definition video taken with a still camera as the craft decelerates on a glide, you can dig out position data and compute speed accurately to the nearest 10th of a mph over fraction-of-a-second intervals, such as every sixth or eighth of a second. As long as the boat carries the same weight passenger, and displays a “ruler” made for this purpose, capturing the data is fairly simple. The analysis is the tedious part.
The picture shows some early results comparing three paddleboards (done before the latest refinements in video analysis.) For purposes of comparing boats, I display their deceleration curves so that they meet at some common low speed. Naturally, the curve with the least slope (slowest deceleration) represents the “fastest” boat, which may be a different boat for different segments of the whole speed range.
I realize that this only shows speed over time, and that resistance would be better represented by plotting deceleration, i.e., the first derivative or slope of the speed curves. That data wasn’t really smooth enough to be meaningful though.
So I’m wondering if there’s any inherent flaw or limitation that anyone can think of with using deceleration on a glide as a means of resistance comparison. Also, when I fit a curve to the raw data, what order of polynomial best represents theoretical declining speed? (I'm displaying mostly 4th order curves now.)
