Yes. They were very good at what they do and they got it to work. Lots of things can go wrong for anyone who tries to repeat the process.Huh? Did you actually go an watch the video, and see how they just put plastic up to the gunnels?
Note: This feature may not be available in some browsers.
Ethylene glycol is highly toxic; to people and the environment. It would be insane to soak your boat with it.Ethylene glycol swells wood the same way water does. It is very slow to evaporate, will diffuse throughout the wood and will hold some moisture, so the swelling is fairly permanent. Wet it down 2-3 times by spraying with a glycol and water solution, letting it dry between coats.
Sorry about that, I forgot about your thread. Long story short, you can't recaulk a dried out hull that has gaps between planks. The planks need swelling at least enough that you can't see the light of day trough the cracks. To do that, staple some burlap to the hull, install a sprinkler or drip line and cover with some loose plastic so the wind doesn't evaporate all the water. It will take a while until everything swells back, don't expect quick results.Also my original question of what to do first hasn’t been answered as far as I can see? Do I reswell the timbers before caulking? And once rehydrated how do I stop her drying out again? Will paint serve that purpose?
Before.My question is do I need to re swell the timbers first or afterwards?
No, you are mistaken, it is toxic, but not highly toxic. Read and understand the SDS before you pontificate. It is less than half as toxic as table salt. The difference is that you can easily swallow one and not the other. The SDS sheets are linked below.Ethylene glycol is highly toxic; to people and the environment. It would be insane to soak your boat with it.
Maybe you should read it. Here is the link to the CDC: Ethylene Glycol: Systemic Agent | NIOSH | CDC https://www.cdc.gov/niosh/ershdb/emergencyresponsecard_29750031.html#:~:text=Ethylene%20glycol%20has%20a%20sweet,Ingesting%20enough%20can%20cause%20death.No, you are mistaken, it is toxic, but not highly toxic. Read and understand the SDS before you pontificate.
How are you going to prevent breathing it after you spray the boat with it?It is safe to handle. Just don't drink it or breath it.
Sigh, again, read and try to understand the SDS. The STEL, 50 ppm, can be avoided with reasonable ventilation because the vapor pressure is very low.Maybe you should read it. Here is the link to the CDC: Ethylene Glycol: Systemic Agent | NIOSH | CDC https://www.cdc.gov/niosh/ershdb/emergencyresponsecard_29750031.html#:~:text=Ethylene%20glycol%20has%20a%20sweet,Ingesting%20enough%20can%20cause%20death.
OK, You win. You can follow me around and make specious arguments until I give up. Anyone who thinks multi speed transmissions are reasonable to expect on a 1950 era 6 hp open utility is not someone to argue with.This is a quote from the CDC, which is more credible than Wikipedia or your paraphrasing:
I said than any small gearbox can be mounted to it. Please don't misquote me. I have done hundreds of installations; many of them with adapters.OK, You win. You can follow me around and make specious arguments until I give up. Anyone who thinks multi speed transmissions are reasonable to expect on a 1950 era 6 hp open utility is not someone to argue with.
