DIY Sportboat; best designs?
Discussion in 'Sailboats' started by rapscallion, Aug 30, 2010.
  1. idkfa
    idkfa Senior Member
  2. Alik
    Likes: 279, Points: 93, Legacy Rep: 1306
    Alik Senior Member
    The problem with forward swept keel was: the foil should be very rigid, otherwise it is twisting.
  3. stubby
    stubby Junior Member
  4. rapscallion
    Likes: 15, Points: 18, Legacy Rep: 132
    rapscallion Senior Member
    Alik, How would the Pluto 800 compare to the Phuket Sports 8 in terms of speed?
  5. Alik
    Alik Senior Member
    Less weight is more speed; generally nothing else :)
    Pluto800 is heavier (1200kg vs 850kg) and designed in 2000 for different Rules, where 1200kg was the lower limit.
    As I remember, on Phuket8 there are bolted wings 2.45>3.03m; so total RM is higher as well.
  6. rapscallion
    Alik,
    How difficult would it be to take the hull design of the K800, and put a higher performance rig and keel on the boat?
    Like say, a rig with:
    Main - 25.6 sqm
    Jib - 16.0 sqm
    Spinnaker - 94.0 sqm.
    and a bulb keel with an 2.5 meter draft?
  7. Alik
    Alik Senior Member
    Can be done, but any sence?
    Structure has to be revised.
  8. rapscallion
    where does one find carbon/nomex developable panels?
    I like the updated thunderbird..
  9. Paul B
    Paul B Previous Member
    I believe Bieker has a local source (local to him in WA State) who can provide the flat panels, pre-cut and ready to assemble.
