Divide Hull with DRAPE
Discussion in 'Software' started by posceve, Mar 8, 2011.
  1. posceve
    posceve Junior Member
    Hi, i need to do this job, project a surface on hull, to simulate fiberglass panel.
    Then unfold intersection and smash to obtain a 2d shape, for cut a real piece of fabric to build a hull.
    Rhinoceros have this command, it's named DRAPE, but it's approsimative.
  2. DCockey
    Likes: 452, Points: 83, Legacy Rep: 1485
    DCockey Senior Member
    What are your starting with? Do you need to develop the Rhino model of the hull from lines or points?
    If you have surfaces then Squish is a plug-in command for flattening surfaces which are not developable and therefore need to stretch or compress. The deformation option allows selection of the type of deformation from stretch only to compress only with steps in between as well as custom type of deformation. The material option allows either rigid or floppy; presumably fabric would be floppy. It appears to only work on single surfaces.
    You may need to download Squish and add it. More information and download here: http://wiki.mcneel.com/labs/advancedflattening
  3. posceve
    Look at this pictures imagine that copper is hull, i start with X number of a sheets of fiberglass 1270 mm long X mm, project them one next others on the 3d hull model.
    I hold the hull of virtual sheets, cut surfaces in surplus, outside the perimeter of the hull, then unroll the surfaces generating a 2D cutting sheets!
    http://db.tt/ggoiEtS
    grazie in anticipo
    http://db.tt/2Pow6Ps
  4. DCockey
    Are the hull surfaces developable?
  5. posceve
    It's split in 3 or 4 longitudinal Rhinoceros nurb surface. Hull is often fragmented
  6. posceve
    look at this picture, explain better than my words!
  7. posceve
    Hi DCockey, your answer has disappeared from the forum...can u post it again?
    :p:idea:
