Dissolving polyester resin
Discussion in 'Materials' started by mojounwin, May 13, 2012.
  1. mojounwin
    mojounwin Junior Member
    Hi Folks, I have some mild steel and lead joined with polyester resin that I now need to seperate. Any suggestions on what chemicals I could use to soften or dissolve the polyester resin? I'm thinking Acetone would be the best bet, just wondering if there are any other ideas?
    Cheers
    Mojo
  2. Frosty
    Frosty Previous Member
    "Fire" and Hammer and chisel.
  3. m3mm0s rib
    Likes: 3, Points: 18, Legacy Rep: 57
    m3mm0s rib Senior Member
    you can heat with air gun
  4. CDK
    CDK retired engineer
    Don't waste acetone on it, that doesn't work. Paint stripper (very alkaline, NaOH or KOH) will slowly weaken the resin, Frosty's solution works immediately.
  5. Herman
    Herman Senior Member
    Methylene Chloride and MEK work as well. But fire and heat usually work faster.
  6. mydauphin
    mydauphin Senior Member
    Or use a high speed grinder, or circular saw to cut it off.
  7. PAR
    If you use enough heat to plasticize the resin so it can removed, you'll also be melting lead.
    Chemicals are the route to take. Freeze it and beat it with a hammer and chisel.
