Displacement boat - speed
Discussion in 'Boat Design' started by Duco84, Apr 11, 2015.
  1. WindRaf
    Likes: 5, Points: 0
    WindRaf Senior Member
  2. Pericles
    Likes: 142, Points: 63, Legacy Rep: 1307
    Location: Heights of High Wycombe, not far from River Thames
    Pericles Senior Member
    The stern on the Poseidon 25 is much wider & the maximum width of beam is extended further aft than the vessel Duco84 has. WindRaf also writes those fatal words " and you can install more power".
    Were it me, I would sell the boat to someone who would be content with its character & build a Lumber Yard Skiff. Look at #6 & #14 in this thread.
    http://forum.woodenboat.com/showthread.php?138899-lumber-yard-skiff&highlight=jclays
    https://www.google.co.uk/search?q=l...&ei=LjAqVfcD19pqw6qAoAs&ved=0CCAQsAQ&dpr=1.88
    The plans are only $60. http://www.oldwharf.com/ow_workskiffs.html
    Use whatever reasonable WBP plywood you can get hold of, build it quickly & take it out on the water. A 50 hp outboard will push it to 50 kph. A month from now you'll be a happy sailor. Take a bit longer & build a pilot house on it, if you want.
    http://www.thehulltruth.com/attachm...ritime-skiff-2090-w-pilot-house-sold-ms33.jpg
    http://s383.photobucket.com/user/kevinmorin_photo/media/Pilot House/pilothouse_terms_1a.jpg.html
    Good luck.
  3. WindRaf
    Likes: 5, Points: 0
    Pericle
    ...is this the point.
  4. Pericles
    We has a phrase in English that says it all. "You cannot make a silk purse out of a sow's ear". You might know something similar. "Non puoi cavare il sangue dalle ****".
    Some tasks are not worth considering. "By knowing things that exist, you can know that which does not exist." Miyamoto Musashi.
  5. FAST FRED
    FAST FRED Senior Member
    The slender stern sinks more than a transom stern does when the boat is pushed hard.
    Plates will help stop the stern squat , but any real speed increase will be minor , tho the stern wave will be smaller.
    Perhaps 1/2 K faster at top speed . .
    Herrishoff did plates to some of his canoe stern boats , not very successfully.
  6. Joakim
    Likes: 53, Points: 28, Legacy Rep: 422
    Joakim Senior Member
    There are some really fast double ended boats in Finland. They tend to be quite light and have a lot of power.
    This one is probably the fastest reaching 40 knots: http://www.friddemartin.net/fakta
    This one "only" 25 knots: http://www.nettivene.com/moottorivene/fiskari/544748
    Both have very much modified hulls and perform almost like planing boats.
    The boat discussed here is large and probably heavy and has a too small engine to be a semi-displacement or a planing boat. Why not just travel at 6-8 knots with rather low fuel consumption?
  7. Duco84
    Likes: 2, Points: 8, Legacy Rep: 18
    Duco84 Junior Member
    I will be satisfied with 10kn as max speead and I hope better stability. Definitely it is possible to achieve higher speed with displacement hull by adding sponsons (Menorquin). Before 15 years on subject boat I had engine with 40hp and I achieved almost same speed as with this one, 100hp. For now sponson, after that probably engin with more power.
  8. PAR
    I have some experience with ideas along these lines, have a patent for one and several designs incorporate it. A European builder is now incorporating similar into their power craft, as well.
    In a nut shell, these wings (as in my case) or shelves, work only within certain speed ranges, on certain hull types and unless adjustable (computer controlled) are just drag, in the other speed ranges the hull form may operate in. My approach was to modify the stern wave to permit semi plane speeds, with less power and over a longer range without significant trim changing, at least as much as it would without it.
    This shows the asymmetric foil aft, which delays unacceptable stern squat, permitting speeds higher into the semi plane mode, without excessive trim angles chewing into potential and efficiency. Again, it's effectiveness is limited and across a fairly narrow range (if fixed), plus it takes a good bit of knowledge, experimentation and testing to get is remotely close to effective.
  9. Rurudyne
    Rurudyne Senior Member
    I wonder how the guy who changed engines out felt about only getting 2 kt extra out of her?
  10. nzboy
    Likes: 6, Points: 18, Legacy Rep: 36
    nzboy Senior Member
    Im just guessing but maybe his current motor is not loaded enough a change of gearbox to 2:1 may improve speed
  11. Mr Efficiency
    Hey PAR, what and where is the "asymmetric foil" you speak of in that picture ?
  12. tom28571
    tom28571 Senior Member
    Yeah, Paul,
    I would like to see how your solution works and see how it differs from what I use and what Walt Shultz has at Shannon Yachts?
  13. WindRaf
    Likes: 5, Points: 0
  14. DCockey
    DCockey Participant
    That boat appears to have a planing hull bottom. At planing speeds with water separating at the chines the shape above the chines does not affect performance.
  15. Joakim
    Yes, as I said they are heavily modified.
    1. misanthropicexplore
    2. Guido
    3. Kingston
    4. Devu De Goa
    5. johnnythefish
    6. M.Raven
    7. TealTiger
    8. Theotilus
    9. DocScience
    10. nimblemotors
