Pocket Cruising Power Catamaran Design capable of safely ranging throughout the Caribbean at low acquisition and running costs...
Firstly, for those who don't keep an eye on macroeconomics, the world is now well into a recession that will soon deepen into a long lasting depression in the US and EU: discretionary spending is dying, as Rv's sales are down 60%, cars down 35% and boats down 30% for 2008. Around one half of today's boat manufacturers, dealers and engines makers - think of Brunswick, Bombardier, etc... - will be bankrupt by the end of 2009...
Yet, these are times for radical thinking in boat design to suit the conditions and the residual market: in my home base of the Cayman Islands, I'm planning to build a Pocket Catamaran Cruiser in the 25' range, as a one-off using Duflex panels. I would recruit an unemployed experienced boat builder and then, if the prototype is successful, go into production building in China or Turkey, using the one-off as a plug...
Here is the design brief, using the best features of several existing designs as a base to work from:
This catamaran pocket cruiser should be seaworthy enough to cruise the entire Caribbean with open water passages not exceeding about 200 miles and capable of 30 knots top speed, with 22 to 25 knots cruising: the Morelli/Melvin Corsair 22 Foiler appears to be one of the best hull design out there, as it banks nicely inwards in turns due to its asymmetric hulls, has wide chines to keep the spray down and displays a very clean wake that speaks well for its efficiency. It's now built by Spartan:
haasmarine.com/Action_Shots.html
Then, there is the Prowler 950VT, which has some well thought out features, asides from what appears to be a very efficient hull: sharp entry at slow or high speeds, load carrying ability aft where the weight is usually concentrated, easy access to hulls from bridgedeck and clever location of the outboard engines, which have a clear water flow while keeping the stern platforms free. This also moves the engine weight and prop further forward, reducing potential aeration in rough seas.
950VT: http://www.schionningdesigns.com.au/login/pages/images/StudyPlanProwler950VT.pdf
Build detail: http://www.schionningdesigns.com.au/login/pages/images/VTmanualbuildsequence.pdf
Video 650VT: http://www.youtube.com/watch?v=gcbIk1GX4V8
I can't help but wonder whether the best features of both designs could be incorporated into one super-duper pocket power catamaran...
The ideal size is around 7.5 x 3 meters or near enough 25' x 10' - some 18" of stern platform could be additional - so that the boat can still be pulled out of the water when a hurricane is coming and towed as a wide load: 4 stainless steel chain plates where slings can be attached directly for crane lift would also be a good idea. Ideal power would be twin 4-stroke or Etec engines in the 60 to 90 hp range. Bridge deck height to be about 2' at rest or at least as high as that seen on the Prowler 950VT.
The general styling of the cabin would be in line with the Tomcat: http://www.c-dory.com/boats/tomcat_255/index.html but with the front windscreen slope inverted slightly as in this boat: http://www.tolandmarine.com/ad_index.htm to reduce solar heat penetration and glare.
There would be a large forward hatch that would incorporate part of the forward vertical trunk cabin to give full access to the anchoring gear - with anchor stowed on a small bowsprit - while standing on the forward berth and without having to walk on the narrow side decks. It's design will need careful attention to avoid leaks while driving into seas and could incorporate a separate smaller aluminium framed acrylic hatch with screen.
The main cabin would have the steering station near centre line with access to the hulls on both sides. To port, a 4 person dinette with athwartships bench seats, the front seat having a reversible back, so that the persons sitting there can either face the table or forward. The entire set up to be dimensioned so as to convert into a double berth. To starboard, a galley with sink, 2 burner stove and storage: the fridge could be located there as well, or under the pilot seat.
In the port hull, aft of the stairs is a toilet compartment with marine head, washbasin and shower behind which will be located the fuel (400 litres/100 gallons total) and water tanks (300 liters/80 gallons total) near the center of gravity. Forward of the stair access is a hanging locker and storage. In the starboard hull forward would be an athwartships queen size berth with hanging lockers and storage forward in the hull and also aft of the stairs.
The roof of the cabin would have small extensions 2' to 3" all around, except forward where it would be about 5" to 6" and aft, where it would extend over 3/4 of the cockpit area and side deck width by the main cabin would not exceed 6". Finished ceiling height in the main cabin should be around 1.95 meter or 6'6". A small arch in line with the aft bulkhead of the main cabin would carry antennas and lights. The outer deck top edge would have a small radius to make it easier to jump on the dock and a rub rail would be integrated in the top sides.
Hopefully, the engines could be recessed into the inner side of the hulls - as in the Prowler 950VT - to free up a good size stern platform for boarding or pulling up large fish. Permanent storage for a Honda 2KW gasoline generator, so that the exhaust faces aft and outside the boat would be incorporated into the aft beam, that will also have seating and fish boxes. Of course, lots of light and ventilation in a hot and humid climate is essential.
I would like to hear your comments on this project and if you're an experienced Duflex boat builder interested in relocating to the Cayman Islands, where your income will be tax free, please reply here or contact me at unikay@candw.ky
