Dinghy Plans
Discussion in 'Boat Design' started by bristol27, Jul 3, 2012.
  1. bristol27
    bristol27 Junior Member
    I am looking for suggestions for dinghy plans.
    I would like to build an excellent cruising dinghy. It must have the following characteristics:
    + Sails
    + Rows
    + Can be stowed in a deck area of about 4' (between the mast and doger, on the cabin-top). Likely meaning the dinghy must be nestable.
    + Buoyant when flooded
    + No engine mount necessary (will use wind/human power only)
    Might you have suggestions for designs I could investigate that meet the above characteristics?
  2. messabout
    messabout Senior Member
    Try the forum search function for nestable dinghys.
    Dave Gerrs book, The Nature Of Boats, has a very nice little dink that might fill your needs. It is called Nester. He gives you all the information you need including a table of offsets. He also shows a nifty three piece kayak like nesting boat that is sure to go more quickly than the dink.
  3. bristol27
    Good suggestion, I have the book here, but forgot I had read about this one. It's a nice dinghy, and at 5'10" nested, it should fit on deck. It just doesn't sail.
    Maybe I need to consider no sails, but I see them as important without a motor. I'd also want to use the boat for 1 - 2 day camp cruises at some destinations.
  4. KJL38
    Likes: 12, Points: 8, Legacy Rep: 75
    KJL38 Junior Member
  5. Mick@itc
    Likes: 4, Points: 0, Legacy Rep: 49
    Mick@itc Junior Member
  6. messabout
    You can adapt the Nester for sail without difficulty. There are plenty of take aparts out there so I expect that you can find something that will fit your needs and a few of your wants.
    Good hunting and fair winds.
  7. beernd
    Likes: 1, Points: 0, Legacy Rep: 27
    beernd Junior Member
  8. rwatson
    rwatson Senior Member
    This is a very impressive design, and after a bit if searching, I found Dannys email address, and he does take PayPal.
    dtgreene@logic.bm
    Offshore Design Ltd., PO Box GE 213, St. George's, Bermuda GEBX
    I think I will order a set - its a great little boat.
  9. Eric Sponberg
    Likes: 209, Points: 73, Legacy Rep: 2917
    Eric Sponberg Senior Member
    Bristol,
    You can try my Halfling, a sailing and nesting pram. The whole boat and its building frame are made out of 4 sheets of plywood, 2 at 1/4" thick and 2 at 1/2" thick. The mast and boom are made out of closet poles. Plans are $20. See my website: http://www.sponbergyachtdesign.com/HalflingPlan.htm.
    I hope that helps.
    Eric
