Doug Lord
Flight Ready
- Joined
- May 26, 2009
- Posts
- 16,679
- Reaction score
- 354
- Location
- Cocoa, Florida
Just to round out the various possibilities here are the preliminary specifications of an 18' trimaran designed to be self-righting-that is: automatically self-righting like a keelboat. It is highly experimental and a model is being built to test the concept. Should the model tests go well the full size boat would be built on the same hull as the Trapwing in the previous post. Should the tests pan out then this will be the highest performance singlehanded boat under 20' I know of suitable for disabled sailing.
Thread that provides details of the model being built now to test this concept: http://www.boatdesign.net/forums/mu...-self-righting-trimaran-test-model-36058.html
The first preliminary design numbers are based on work I did for a two person 18' tri in another thread in the multihulls forum.. They have been "massaged" to meet the goals of an automatically self-righting small trimaran. No consideration of cost is given here since the boat is highly experimental. The numbers show that this boat will probably right itself from a capsize or a pitchpole-this must be confirmed by model and fullsize testing.
This boat is designed as a SINGLEHANDER. For this version the ama will be either full flying (preferably) or foil assist only. These dimensions are preliminary and are bound to change as a result of testing and/or design refinement:
Self-Righting Trimaran(SRT) / Preliminary Specifications:
Length: 18' / 5.49m
Beam: 22' / 6.7m (foldable for trailering)
Ama LOA: 12'
100% ama buoyancy: 375lb.
Draft w/boards Up: 6.4"
Draft, daggerkeel down: 4' 8"
Mast Length: 28' / 8.3mm
Sail Area:
--277 sq.ft. upwind SA
--575 ft2 / 53.4 m2 downwind SA
Weight (with spinnaker): 400 lbs / 181.9 kg
Crew weight: wide range-for these numbers 175lb.
Ballast: (at the juncture of the daggerboard and main foil)- 175lb.
COMPARITIVE RATIOS:
Bruce Number: 1.83 F18=1.66
SA/WS:
-- not flying-5.73/1 F18=4.77/1
-- flying main hull-10.26/1 F18(flying one hull)=6.03/1
SA/D: 53.89 F18=44.16
W/SA-smaller better): 2.71 F18=3.29
How it works:
1) the boat is designed to carry the weight of a crew in a wide weight range. For the numbers above the crew weight is 175lb..
2) The mast is carbon and sealed. It has masthead flotation structurally integral to the mast. Shrouds are fiber and designed to support the mast in a capsize or pitchpole.
3) The dihedral of the cross arms is 15 degrees.They must be carbon tube.(elliptical section if possible-NA)
4) the sailing angle on foils is 13 degrees.
5) the sailing angle with ama partially immersed is 19 degrees.(very tentative-boat is likely to be fully flying foiler)
6) When the boat is capsized the RM exceeds the heeling moment(approx 500ft.lb. with sails uncleated) by about three times because:
a. the center of buoyancy of the ama is 2' toward the mast tip from the CG of the boat giving a large righting moment(750ft. lb). This is due to the high cross arm dihedral and ama buoyancy of 375lb. The ballast in the keel is 5' from the hull CG giving an additional RM of 875ft.lb..
b. Same is true when pitchpoled: the boat would be nearly vertical before starting to right. In this position each ama has about 180 lb. of buoyancy acting 2' from the CG of the boat. And the keel ballast acts as in a. above.
7) No action is required of the crew to initiate righting except to uncleat the sails(and even that may not be necessary).
8) From discussions with people who have sailed the Rave and Hobie Trifoiler it is clear that NO FORM OF RESTRAINT should be required to sail this boat. Testing is the only way to evaluate the suitability of this self-righting trimaran(SRT) for use in disabled sailing or for sailing by those with any kind of infirmity.
These preliminary numbers(and the sketches I've done to arrive at them) show me that the boat is very high performance and that it will automatically self-right.
Length: 18' / 5.49m
Ama LOA: 12'
Sail Area:
COMPARITIVE RATIOS:
SA/WS:
How it works:
