seanseward
Junior Member
- Joined
- Dec 15, 2013
- Posts
- 11
- Reaction score
- Location
- United States
Making a kick-up rudder for my Neptune 16.
After reasonable research I have decided:
It will be 2x 3/4" marine plywood pieces glued together to make a 1 1/2" board, planed to foil shape, glassed, finished with epoxy filler and painted with gel-co or some marine paint. Cheeks will be 1/4 alluminum. gudgeons will be inset on inside of cheeks (similar to Laser Bahia system). I have foil dimensions from http://en.wikipedia.org/wiki/NACA_airfoil and http://web.utk.edu/~pdf/newport/newport/newport.htm. I will use current rudder for template.
I need to reduce wood width to accommodate glass work and finish in order to fit within current pintles made for 1 1/2" rudder. What would normal glass work (layers) look like and what is skin thickness (http://www.fastcomposites.ca/site/marine/design-tips-fabrication-overview/helpful-calculations/) of this glass work?
Questions:
1. What is basic glass work layout for this job? How many layers, of what type of glass and what weight? I will use West Marine Epoxy.
2. What is final "skin thickness" of this suggested glass layout?
Questions:
