Difference between Class rules, Flags and conventions.
Discussion in 'Boat Design' started by thpphrsis, Jun 8, 2018.
  1. jehardiman
    Likes: 1,373, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Maybe we have dragged this off the OP's topic and down into the grains of sand. To answer the question which to use, you flag state or the primary sponsor will set the required legal code or class rules to use. Often the financer will set a higher requirement so the vessel is saleable if the primary owner defaults. In the USA, the vessel must meet US CFR Title 33 and CFR Title 46 as well as the class society (ABS, GL, DNK, etc...).
  2. Ad Hoc
    Likes: 1,897, Points: 113, Legacy Rep: 2488
    Following on from JEH..
    This should be stated very clearly in the technical specification of the vessel. It should state the Class and Flag rules to which the vessel is designed to satisfy. Simple as that.
