Diesel/Electric Propulsion for Sailboats
Discussion in 'Hybrid' started by westsail42, Nov 3, 2005.
  1. Vega
    Likes: 26, Points: 58, Legacy Rep: 132
    Vega Senior Member
  2. HawkeyePierce33
    HawkeyePierce33 New Member
    Re-e-power
    Here is another site that might be a little cheaper for the do-it-yourselfer. Has anyone tried one of these conversions? www.re-e-power.com
  3. Raggi_Thor
    Re-e-power!
    Very interesting and rather low cost, compared to the european (Denmark and Austria?) solutions probably mentioned before.
    And in a sailboat, the batteries can be used as moveable ballast :)
  4. HawkeyePierce33
    Yes, and here in Canada we can buy adsorbed glass mat batteries at our national hardware store for about $105 for 35 A-h, and solar panels (if you look hard) for about $5/watt.
  5. Vega
    Vega Senior Member
    Well, I have good news about the Diesel electric solution. I guess that everybody has understood that I consider it the best solution for a cruiser, even for a sailboat, or should I say a Motorsailor... cause it looks that today all true cruisers have some kind of motorsailing capability.
    Anyway I would like to have one of those systems in my next boat but I want to avoid the inevitable problems and ningles that a new untried system will give.
    To sort out those problems, nothing better than a mass-market product...and it happened already. One of the boat companies from the Beneteau group has produced a boat that comes standard with a Diesel-electric...and there is not even an option for a conventional engine...and the boat is not more expensive than the previous model with a conventional engine.
    The boat wastes a lot less fuel, can work for hours only on the energy from the batteries...and it looks too good to be true.
    Beneteau says that this is only the beginning of the conversion of all their boats to Diesel-electric.
    I guess that it is only a question of time before Bavaria join forces with Fisher/Panda.
    What boat am I talking about? Come on guys, I will let you have the pleasure to find it out:D
  6. Vega
    Vega Senior Member
    Ok, the boat I am talking about is the new Lagoon 420, made by jeanneau (JTA), a member of Beneteau group. They have produced 260 Lagoons in 2006 (all models) and they have received already 60 commands for this model. If you command one now, you will have to wait one year for delivery…and the time for delivery is increasing rapidly because they didn’t expect so much interest in this new concept.
    Here are some info about the boat and the propulsion and energy management system:
    http://www.cata-lagoon.com/pdf/Lagoon420_brochure2006.pdf
    http://www.catamarans.com/news/2006/05/Electric_Lagoon420.asp
    http://searchwarp.com/swa61868.htm
    http://www.sail-world.com/newstext/pda.cfm?Nid=27173&RequestTimeOut=180
    For the ones who can read French, there is a big article and a boat test in the September edition of "Voiles et Voiliers".
  7. FAST FRED
    FAST FRED Senior Member
    Just wondering what the price would be to put 75 to 150 hp to a prop , compared with a std shaft and tranny.
    FAST FRED
  8. Vega
    Vega Senior Member
    Fred, I believe that the price has a lot to do with production numbers. If you have to customize each installation the price will be probably 2 times bigger, than the one you can offer if you made 100 standard systems.
  9. FAST FRED
    "I believe that the price has a lot to do with production numbers."
    Then the advantage would have to go to a hydraulic drive for an unconventional boat , and std tranny /shaft prop to a conventional boat.
    Here is a new boat plan that might or might not ever get built , and work.
    http://www.dsehybrid.com/
    Interesting that they will build the engines foward with a WT bulkhead .
    The only vessel I have seen with this engine location , Feng Shuey (sp?) was a large 60 ft or so motorsailor with a 6-71 in the bow , and 2 gen sets!
    It had a mechanical windlass driven off the front of the DD , and at least 45 ft of shafting with pillow blocks and a std prop.
    As sleeping foward in a sea way stinks , it looks like a great idea , esp since engines don't have to weigh 3000+ lbs for reasonable output. She had completed 2 circumnavigations.
    FAST FRED
  10. mattotoole
    mattotoole Senior Member
    Output of regen under sail
    I'm curious about the output of these regen systems (Solomon, etc.) under sail. How many amps at 6kt, for example?
  11. bertho
    Likes: 5, Points: 18, Legacy Rep: 59
    bertho bertho
    mattotoole,
    i wondering to.. probably less +-1 knt for the sailing boat and ..somes amps. ?? as propeller are not desing to work on this side..forget foldable prop, but you will have noise from shaft, vibration on the rudder... I don't think we can have the butter, the money and the farmer..
    cheers
  12. Raggi_Thor
    You mean we can't eat the cake and have it?
  13. bertho
    bertho bertho
    raggi, yap! .. french sentence.. ( sometime we talk also about the wife of the farmer.!!.)
    rgds
  14. Raggi_Thor
    I would like to hear that one, about the wife :)
  15. Vega
    Vega Senior Member
    Probably you are right. If I bought a cruising boat right now, I would still choose a conventional std tranny/shaf prop and a Genset, or I would buy that Lagoon, that has a Diesel-electric std system (with an adequate warranty, on all the system) and that is not really an option because I don't feel comfortable with cruising Cats.
    But, looking at the huge interest that the hybrid Lagoon has raised between clients and given the Beneteau group interest in applying this system to all his range of cruising boats, this actual situation (regarding production numbers and reliability of the system) is going to change fast and in some few years (hopefully) this system will be the standard choice to all true cruising boats, at least to the ones that now need a Genset and an Engine.
    The initial costs will not be superior and the advantages of the Diesel-electric in running and maintenance costs, not to mention the substantially increased flexibility in the possibilities of the interior design, will be overwhelming.
