Diesel Boxer
Discussion in 'Diesel Engines' started by pcn, Feb 28, 2006.
  1. pcn
    pcn New Member
    Has anyone encountered a diesel engine (marine or otherwise) in a "boxer" configuration - or is there some showstopper unique to diesel combustion that disqualifies this option?
  2. moTthediesel
    Likes: 4, Points: 8, Legacy Rep: 21
    moTthediesel Junior Member
    Well, there are the Fairbanks-Morse horizontal opposed piston engines.
    They could truely be called "boxers" as their pistons could be seen as punching at each other :D
    For something really wild, check out the Napier Deltic engine, with three banks of opposed piston cylinders arranged in a delta shape, with three crankshafts geared together to the transmission.
    There'll always be an England ;)
    moT
  3. antonfourie
    Likes: 2, Points: 0, Legacy Rep: 13
    antonfourie Senior Member
    The English do like their strange engines, like the rotary engine from WWI where the crankshaft was attached to the aircraft, and the prop was attached to the cylinders which spun around the crankshaft.
  4. moTthediesel
    It wasn't only the English that used rotary aircraft engines in WW1, the French Gnome et Rhone engine was used in many of their aircraft as well.
    There was no way to throttle those engines, so they ran "wide open" all the time. They were controled by switching the ignitions off and on, that accounts for the strange "burst of revs" sound you hear as they land. :cool:
    moT
  5. StianM
    Likes: 23, Points: 18, Legacy Rep: 114
    StianM Senior Member
    I belive the Danish Callesen or something like that made diesel boxers for ferrys. This was done to get them fitted under the low deck's
    Maybe it was a other? I'm shure it was danish
  6. StianM
    [​IMG][​IMG]
    The engine to the right is a Napier Nomad. It's the same construction, but the Nomad is a compound engine, It's developed during the 50's, but stil hold the record as the moust fuel efficiant aircraft engine ever buildt. There was fuel injection to the compund so that power could be increased during take off
  7. moTthediesel
    Dats watt I'm talkin' bowt :D
    Thanks for posting that animation, v. cool :cool:
    moT
  8. StianM
    You have ti be sick to make a engine like this and mentaly ill not to like it.
    I'm still wondering if it was callesen or not the produced those ferry boat boxers.
  9. waqas20
    waqas20 New Member
    Yes there is a diesel (jet a fuel) called diesel air but I think they could be used in the marine world. Diesel air did try
  10. FAST FRED
    FAST FRED Senior Member
    "There was fuel injection to the compund so that power could be increased during take off"
    Are you sure ?
    Usually the old recips were water or water alcohol injected to allow higher (5 min limit) take off power.
    Our 3350 3 row recips would pull 54 inches of manifold pressure at 2900 with the water on.
    Only 48 inches MAP without the water
    Pair was mounted on Neptune P2V7,s.
    FAST FRED
  11. StianM
    Water and alcohol was injected to the air intake for combustion.
    Here the fuel is injected betwen the engine and the compund turbine and is burned in the extra okygen you find in a diesel engine. ;)
