Very few "round-bottom" hulls have actual round hull sections. Most have compound curve ones, which have segments that are often very close to being straight.
These are the easiest ones to turn into hard chine. If you are willing to go to the trouble of rounding off the corners where the panels intersect, you end up with a hull that looks very much like a round bottom one. This rounding off is accomplished by use of pipe sections, for metal boats, and often strip planking, for wooden ones.
If one is not willing to go to this trouble, one can merely snip the corners and add smaller panels there, then end up with a multi-chine hull, with each added panel adding another chine.
The name of the game here is get as close to the shape of the original rounded section as one can, with as few panels as possible, while maintaining the exact area of the original rounded section.
This can often be accomplished with just two chines per side (meaning three panels, if the bottom of the section ends with a "V" ). Sometimes a third chine is needed. And even rarer, a fourth one. The rounder the original round section is, the more panels and thus more chines are needed to imitate it.
It is best to keep the panels curved in in one plane, with as little twist as possible.
But often some twist is needed to get the proper hull shape. When this happens, life gets a lot more interesting. To get this twisted panel to follow a curve, it has to be taken from an enormous cone--hence the term "conic development". Sometimes it will be necessary for a single panel to be taken from more than one cone, and the it gets called "multiconic".
Using these two types of panel development, without having to draw the gigantic cones is possible, using several drafting techniques--which I have yet to master.
Right now, I am playing with a faceted imitation of a scaled-down Spray hull by using less than 20 facets (absolutely flat panels), not including the full-length keel.
What I am ending up with, will never be mistaken as a small Spray hull. But it will be clear that it is an attempt to imitate one.
