Deutz aircooled engines for marine propulsion
Steel Builder
Junior Member
Joined
Aug 17, 2017
Posts
7
Reaction score
Location
Denver, CO
Anyone has experience with Deutz aircooled engines ? Deutz makes the D914 L5 industrial engine application and it is Tier III . I dont know if I can use it for marine application . Plain ventilation in engine room (6 ' long x 12 ' wide x 6' height)
I used Deutz air cooled, but not that size, much smaller. Yep, just about any diesel can be marinized, though some parts will need fabrication, if unavailable as marine.
Contact:
Anderson Equipment in Kansas, 785/9443370, which looks to be the nearest dealer to you.
Contact:
Thanks Par. Aircooled Diesel engines don't need to be marinize . All the marine air-cooled engines offered by Deutz are the same as industrial . My question is if I use an industrial Tier III version engine in marine application will the EPA still consider the engine as Tier III.
As I understand the new Deutz 914 engine noise have been reduce from previous models . No idea what number .
Are you building new boats that need to comply with EPA?
yes, it is a new boat and engine needs to be Tier III. Not to many Tier III in the 90 HP range .Most of what I look are high speed , expensive and high consumption. Maybe because the common rail injection system.
The common rail, electronically controlled engines are going to have as low consumption as it gets. They are state of the art. You are saying "boat" in the singular. Is this for a single boat?
It's will be hot in the engineroom. Air cooled engines usually have short lives in enclosed spaces because not enough cooler air is available. Probably half life or less. As the oil heats, it looses some of its ability to lube. Cylinder parts will wear like you're running a turbo. Hotter incoming air = less power. Hot ambient air = less cooling of the cylinder. It's like having excessively high exhaust gas temperatures.
Air cooled installation can be short lived, if not properly setup. They're not inherently doomed, though some concerns do need to be addressed, if you'd like a reasonable life span. More than anything they're loud, but this too can be addressed and many very good products and materials can address this issue as well.
As a past custom aluminum yacht and boat builder, I can say there is few engines that can compare with a Deutz. The aircooled engine brings a lot to the party, but needs special air cooling ducts and combustion air ducts to work properly. Getting the air in for cooling and combustion is no problem through a proper demister. I've done several. It's the discharge air (airflow after piston fins) that need to be routed out of the engine room to keep the heat down in the engine room and not recycle the air into either combustion or cooling air fan. Beyond that, Deutz is a bit noisier than a water cool diesel due to the lack of a water jacket. This is solved with constrained layer dampening sheets under deck plates. Use welded pins and clips or expanded metal bolted in to hold the dampening sheets on. A bit of HT spray glue helps put them up. Bottom line. I have installed 2 cyl. to 12 cly. Deutz and would do it again. If you want some comparison, check the engine speed of comparison engines at say 2400 RPM. Deutz always comes in first for the lowest piston speed. Low piston speed (under 12,000FPM) is a good thing.
