Fine adjustment of daggerboard position
Depending on one's taste, wishes and concerns ... the daggerboard position fine adjustment can be:
(1) geometrical CE on the vertical of the daggerboard leading edge
(2) Davidson CE on the vertical of the hydrodynamic center of the daggerboard (0.20 x chord)
(3) Davidson CE on the vertical of the leading edge
But the big issue is the sailboat Balanced without moving the rudder, or in other words: CLR aft of LCG without moving the rudder, similar to Longitudinal Balance in a passenger or cargo aircraft:
The
Munk Estimate is a Vector that we place right at the bow.
if R x r < m x M: unstable Equilibrium
if R x r = m x M: Neutral Equilibrium
if R x r > m x M: Stable Equilibrium
What happens if the Munk Moment is a huge quantity
Well, you have to make a workaround: move the Sails forward so that the Sail Lateral Force balances the Munk Moment. The sailboat is balanced to sail upwind but it is unstable downwind, and with big waves it is uncomfortable and could even be dangerous.
