Note: This feature may not be available in some browsers.
You are saying that the center of lift of such a hull is at 50% chord, as opposed to a symmetrical foil or flat plate which is 25%? I could see that the center of resistance would be at 50% if simply being pushed sideways but doesn't that change as the hull begins to create lift in motion with leeway?Now it's clearer. What you are looking for is taken, with sufficient approximation, to be the geometric center of the submerged area, seen from the side.
I don't think I understood what you mean either. Excuse me.
I was talking about the center of drift, nothing to do with the center of lift, which I don't know how to calculate in a simple way.
Ok, then we are dealing with a dynamic case. There are two (at least) opposing influences active, both depending on aspect ratio (AR). If you imagine a deep foil with short chord, it has a high aspect ratio. With most "normal" profiles, the pressure center (center of effort et c) lies close to 25 % chord from the leading edge in this case. With diminishing AR, as with a long keel (or a naked hull), the pressure center moves forward.
BUT, with reducing AR, the lateral plane becomes less efficient as a lifting foil due to 3D flows. To create the required lift force now, it has to operate at a higher angle of attack (AOA), resulting in a rearwards transition of the pressure center. The situation is further complicated by the influence of the transverse shape of the foil, or as in dustmans question, the hull. To conclude: there is no general case or shape that is covered by a simple formula.
BUT, again, we can draw some conclusions from existing hull/sail combinations. With traditional long-keeled hulls, you will often find the sail center of effort (CE) about 15% of the keel chord fw of the center of lateral area (think "shadow area"), while for a typical fin keel, the sail CE is found roughly 5% of chord forward of the fin center of pressure (which in turn is found 25% aft of the leading edge). Numbers from Dyne, Eliasson, Heuman and Larsson.
Fiddling with the numbers very roughly, I'd expect that in the real sailing situation, the pressure center of the Wharram hull shape would occur at about 35% chord aft of the "leading edge" of the wetted body.
BUT, encore, there is a mutual influence between the two hulls when operating at a common angle of attack; their separate CE's will not be found at the same longitudinal position.
I think you're catching-on.So what I'm left with is building a small scale boat with the same relative dimensions and experimenting with sail placement? It sounds like an accurate prediction is very difficult to make.
Sorry, I think you two misunderstood the question. I meant for the hulls acting like keels, acting as lateral resistance. I'm trying to figure out where to place the sails(center of pressure) on such a craft, and size and placement of rudders. ...
