I know this is not about boat-building per se but the expertise is directly applicable and your help is appreciated:
We are building 23' X-wing fighter model to raise money for a local school STEM program and need help with the fabrication - we have little experience in this. We are done with the cabin (see video here:X-Wing Fighter on Twitter https://twitter.com/twitter/statuses/920297413197393921 ) and fiberglassed the body but need to fabricate the wings.
The wings are roughly 8 x 4 feet and ideally 2" thick but can go up to 2.5". They are all square with right angles and same thickness throughout. Can we fabricate a fairly rigid wing this thin that will be relatively light and support its own weight plus the "cannons" (see the picture below) at the ends? They will be attached to the body and will move up and down but will not have to endure any stress.
Here is more info about where we are:
Used polyester resin for the body but getting epoxy for the wings to avoid contraction and ensure better strength.
Used 5/32 cardbox (48 x 96" 200 lb. Corrugated Pads S-3194 - Uline https://www.uline.com/Product/Detail/S-3194) as a core but was not impressed with the strength even after getting one layer of cloth from one side and 3 layers from the other. (adding mat mostly seemed to add weight). So, the cardboard may be fine for the body but may not be strong enough for the wings.
Planned to use coroplast (corrugated plastic Search Results for coroplast at The Home Depot https://www.homedepot.com/s/coroplast?NCNI-5)- as a core for the wings but neither fiberglass nor epoxy seem to adhere to it very well.
Questions: what is the core material we should use and how this should be fabricated? Again, we are trying to keep the cost down (more money for the school) and the wings only need to support themselves and the "cannons" at the end. I was thinking of making 2 inch strips of core and then epoxying them together with fiberglass cloth in between. Then using these as "beams" to go between two flat panels (which would also be laminated from both sides with fiberglass. I have a gut feeling that this may not be the best technique and any guidance will be great.
thank you in advance
Mike
P.S. Here are some of the other core materials we have considered:
1 in. x 4 ft. x 8 ft. R-6.5 Foam Insulation-268417 - The Home Depot https://www.homedepot.com/p/1-in-x-4-ft-x-8-ft-R-6-5-Foam-Insulation-268417/100576728
Owens Corning FOAMULAR 1/2 in. x 4 ft. x 8 ft. R-3 Squared Edge Insulating Sheathing-36L - The Home Depot https://www.homedepot.com/p/Owens-Corning-FOAMULAR-1-2-in-x-4-ft-x-8-ft-R-3-Squared-Edge-Insulating-Sheathing-36L/100320356
Hardboard Tempered Panel (Common: 3/16 in. x 4 ft. x 8 ft.; Actual: 0.155 in. x 47.7 in. x 95.7 in.)-832780 - The Home Depot https://www.homedepot.com/p/Hardboard-Tempered-Panel-Common-3-16-in-x-4-ft-x-8-ft-Actual-0-155-in-x-47-7-in-x-95-7-in-832780/202404545
Mike
