It is generally accepted that multi mast rigs are poor performers to windward because of extra drag and bad air caused by mast and sail in front.
Sorry disturbing this thread by trivialitys but that is simply not true. Neither the generality of the claim nor the generality of the "acceptance".
Where does this bad-air argument come from, let's have a look at it:
1) Reducing the view to "classic rigs" with lots of drag making parts - stay, shrouds, diamonds, spreaders, halyars, lazyjacks ... some cruisers really look like a jungle of strings. Of course, nothig get's better by doubling something (aerodynamically) bad - but that doesn't apply to sleek aerodynamic designs like the Haryproas.
2) Isolated consideration of a sail alone. Of course, the sails influence each other - and if two boats sailing close together this is sometimes disadvantageous for one of them. But virtually any boat with a jib proves - in total, both sails together can generate more propulsion than the sum of both sails alone.
3) A commonly heard argument for a high single rig is reduced induced drag. But that is completely dependent on the basis of comparison - so let's compare a single rig with a schooner rig based on the same mast height.
Assume two sails very far apart, so that their mutual influence is negligible. If each produces half the power of a single sail of the same height, then each produces only a quarter of the induced drag - the half in total. Of course, this advantage decreases when you bring the sails closer together - and disappears when you combine them into a single large sail.
--> To achieve the same induced drag single rig MUST be higher than a comparable schooner rig, assuming the overall aerodynamic quality is similar. With all the disadvantages, such as greater forces on larger lever arms, or the more difficult handling of a single large sail area ...
I'm NOT saying that multi-mast rigs are always better. (In my area, with lots of bridges and often limited maneuvering space and, they would be totally impractical. But I'm always surprised when someone writes about a schooner "oh, she did surprisingy well". The only surprise is the over-simplified application of aerodynamic by people who should know better.
