Designer and design needed.
Discussion in 'Boat Design' started by Time, Feb 25, 2008.
  1. Time
    Time Junior Member
    hello,
    I'm in need of a designer/architect, to design and manage the build of a craft capable of competing in the Australian Off Shore Challange. Also fulfilling some rereational needs.
    basic design brief:
    9.5m LOA
    2.8m Max beam
    seating for 5
    capable of a ~60knot sprint
    Preferably diesel inboard.
    Initial design Thoughts:
    VSV
    wave piercing VSV
    Wave piercing multihull
    Please contact,
    Via PM or this thread.
    All ideas, suggestions and designs to be considered.
    Kind reguards,
    Time.
  2. Jendrik
    Jendrik www.odenwald-global.com
  3. Time
    Time Junior Member
    Email sent.
  4. joz
    Likes: 0, Points: 16, Legacy Rep: 10
    joz Senior Member
    Time
    Try Will Allison of Imaginocean Yacht Design he's based in Tassie to which's a power boat designer, ask him if he's interested in designing your boat. You can contact him via email.
  5. Time
    Time Junior Member
    Thanks Joz,
    Will and I went though a process last year, on this topic. But we came to a halt, when our situations did not work out at the time. He was busy with a new project and I had other comitments and needs as time progressed.
    This is a feeler to gauge what new ideas are about and perhaps will see me return to Will, Thankyou for the suggestion though.
    Time.
  6. joz
    joz Senior Member
    Ok no problems
  7. Time
    Time Junior Member
    No other takers?
    I will attempt to give you a list everything I require from the boat, in no particular order.
    - Sprint Speed of ~60knots (some what malliable)
    - Seating for 5
    - LOA 9.5m MAX
    - Max beam of 2.8m
    - Excellent rough sea handelling
    - Berth for 2
    - Storage for 4 sets of dive gear
    - Ecnomical/effecient design
    - 500nm range
    The Australian offshore challange operates in the Bass straight between mainland Australia and Tasmaina, it sees conditions that are quite difficult, so good see keeping is essential.
    Other then that, I prefer to leave the rest to you. I have found a loose framework an essential fostering ground for intuitive and progressive design.
    Past discussions on the topic have yielded, reasonable suggestions, including the following.
    - monomoran idea with Rib and semi stuffing bow.
    - trimiran similar to eathrace
    - Deep V monohull
    - wave piercing VSV (vsv version of a craig loomes waver piercing mono)
    - wave piercing cat.
    Please feel free to explore all avenues of design.
    Information on the challange can be found here.
    http://www.offshorechallenge.com.au/
  8. Tad
    Likes: 191, Points: 73, Legacy Rep: 2281
    Tad Boat Designer
    Just off hand that sounds like one hell of a challange.....Capable of 60 knots.....500nm range? At what speed? Has any 9.5m boat actually done this? Is this boat classed?
    Your link would not work for me.
  9. Time
    Time Junior Member
    Well like was mentioned above, the 60 knots is quite open for discussion as are most of the other parameters. I do envisage 35 knots or there abouts as a cruising speed.
    I"m not sure what is wrong with the link. but if you do a google search, you will find the information.
  10. Eel Pie
    Eel Pie New Member
    Any progress?
    Hello,
    I wonder if you made any progress in designing your race powerboat. I am interested in the similar idea of a monohull vsv powerboat, more or less the same dimensions. Have you found any designer yet or have you given it up?
    Regards, Thom
  11. Time
    Time Junior Member
    Sure, the design was fully evaluated and finalised but never built due to a lack of capital on the part of an investor. Unfortunatley i'm not able to enter into further discussion.
  12. Time
    Time Junior Member
    Adding to my post above,
    The design was completed inc CAD files construction notes and scheduling. Several models were also tank tested and fully evaluated.
    With performance predeiction very close to what I required.
    I had yard ready to construct and would go back to them should i decide to build the boat at a later date.
    This will be my final post in this topic.
  13. CastrolR
    CastrolR Junior Member
    Can I help, I would be very interested to get involved in your project and I invite you to take a look at http://www.vipermarinegroup.com
    Please drop in a email or make a further post to this thread
  14. Çemberci
    Likes: 6, Points: 0, Legacy Rep: 133
    Çemberci Senior Member
