Design standards required by law
Discussion in 'Boat Design' started by jdworld, Nov 20, 2009.
  1. jdworld
    Likes: 2, Points: 0, Legacy Rep: 50
    jdworld Junior Member
    This is way off topic, but something i have been trying to find out recently for a something I am working on. Specifically, who requires things in boat design? What is the governing body, and where can I find their requirements? In researching around it looks like the main governing body seems to be the ABYC. HOWEVER, it seems that although they have lots of "standards" that they lay out, I have read that they are really only voluntary standards, not required by law. So where might I go to find out what IS required by law in boat design? Does a boat mfgr have to get the equivalent of a "building permit" for a new boat design? For cars, it's probably the National Transporation Safety Board. For airplanes it's the FAA. Who is it for boats? The Coast Guard?
  2. apex1
    apex1 Guest
    DNV, LLoyds, German LLoyd, BV are providing the "standards" for small boats. ABS does´nt.
    There are no building permits or something equivalent. Not in car or airplane manufacturing also! But the products have to be approved. (which in consequence can mean having "certified" staff)
    But in general every one armed monkey can setup a boatyard.:cool:
    Regards
    Richard
  3. Fanie
    Fanie Fanie
    Richard is right. Any one can build basically any thing. The onus is on you to do it so that it will be acceptable to use for it's purpose and it doesn't pose any kind of threat or hazard. That said, quite a few out there just breathing poses a huge threat and hazard :rolleyes: but let's not go there :D
    I think the general 'rule' of what is sensable to use is to look at what others did before you. If that can be improved on and calculations concur then let rip. Always a good idea to let a pro check things through for you, just in case one misses the obvious.
  4. terhohalme
    Likes: 38, Points: 28, Legacy Rep: 506
    terhohalme BEng Boat Technology
  5. apex1
    apex1 Guest
    Well, it is...............
    ABS Guide for Offshore Yachts, approval for yachts under 24 metres withdrawn some years ago!..................
  6. pamarine
    Likes: 3, Points: 0, Legacy Rep: 70
    pamarine Marine Electrician
    For Manufacturers selling boats in the USA, the USCG is the governing body and sets all the standards for design and contstruction. You are partially correct when you say ABYC Recommendations are voluntary. Several of the ABYS chapters are now referenced in the USCG Regulations, and therefore have become law.
    A reference for small-boat manufacturers can be found at http://www.uscgboating.org/regulations/boat_builders_handbook_and_regulations.aspx
    The complete list of the applicable regulations to the design and construction of boats can be found at http://www.uscgboating.org/regulations/federal_regulations.aspx
    That being said, anybody can build a boat as long as they intend to use it only for personal use. It is still advisable to follow industry standards and the USCG has several resources available to backyard builders.
  7. pamarine
    Actually, for production aircraft (aircraft that at least 50% are built in a factory by someone other than the end user), the FAA issues a Production Certificate along with a Type Certificate after extensive testing of each new design. Without these two certificates, it is illegal to manufacture aircraft intended for sale or registration in the US. As stated, this does not apply to ultralights or homebuilts (51% must be built by the owner)
  8. Kay9
    Likes: 26, Points: 0, Legacy Rep: 279
    Kay9 1600T Master
    In the US the rules are covered under the Code Of Federal Regulations. Everything from MARPOl to EPA you simply have to do a search on "CFR Shipbuilding"
    K9
  9. apex1
    apex1 Guest
    Pamarine
    you´ll find that I already pointed towards "certified staff" which of course can include almost all staff.
    K9
    that does´nt apply here.
  10. Kay9
    Kay9 1600T Master
    I didnt say it applied in Germany. I said in the US the rules of shipbuilding are covered in excrusiating detail in the Code of Federal Regulations. If you are building a ship/boat/airplane/truck/car/motorcycle the "governing body" in the US is in the CFR as per jdworlds request when he asked and I quote:
    "What is the governing body, and where can I find their requirements? In researching around it looks like the main governing body seems to be the ABYC."
    K9
  11. pamarine
    The staff doesn't have to be certified in anything, unless the manufacturer requires it. The Aircraft design is what is being deemed airworthy. Airworthiness standards are found in 14 CFR parts 21 through 39
  12. apex1
    apex1 Guest
    Jaja,
    no certified staff, hmm.
    uncertified ally welders, uncertified cfk laminators, no masters, just monkeys.
    I think we are (as usual) talking completely different worlds here.
    The question was "boat design" and "building permit"
    The answer is: NO you do´nt need. period
  13. pamarine
    The question was "'Governing Body for Boat Design and Construction." And yes, the boat does have to meet certain requirements under the law, period.
  14. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    it used to be and may still be that once type certification was approved then the manufacturer certified each airplane as complying unless its for the military
  15. dockdave
    dockdave Junior Member
    No permit recquired in my backyard
