One of the factors that modify the design pressure is the "pressure reduction factor kAR", which in turn depends on another factor kR. For bottom side and deck stiffeners kR = 1 - 2 * lu/10^4.
When the unsupported length of a stiffener is equal to 5000 mm, this factor is reduced to zero, so the design pressure is zero. So how can a stiffener of this length or greater be calculated?
Furthermore, the larger the beam, the lower this coefficient and therefore the lower the pressure acting on the stiffener.
Thank you for your opinions.
