Design help needed
Discussion in 'Boat Design' started by Taylor Waters, Aug 23, 2023.
  1. Taylor Waters
    Taylor Waters New Member
    I have never built or designed a boat but have contemplated building a small(12’) fishing skiff. My original idea was to construct it much like a fiberglass paddle board and have a solid foam core with the glass laid over it. I haven’t been able to find anything online on weather it would work or not so any input or better ideas for design/construction are welcome
  2. bajansailor
    Likes: 1,784, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    Welcome to the Forum Taylor.
    As a start, you could perhaps try renting or borrowing a paddleboard and testing it out to see how well it would work as a fishing boat (I have a feeling it might not work very well) - it would be worthwhile doing this first before investing time, effort and materials into building a board.
    Duckworks has an extensive array of small boat plans for sale - have a look through their site and see if any of their existing designs might appeal to you?
    Plans & Kits - Plans by type - Page 1 - Duckworks Boat Builders Supply https://duckworks.com/plans-by-type/
  3. kapnD
    Likes: 538, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Search you tube, there’s lots of that type of craft being built.
  4. Taylor Waters
    I have been on paddle boards a good bit and fishing from them isn’t as bad as you might think.
    Also thank you for the link, I do see a couple I like I may opt for but I’d like to see if I can find more information on my original idea as well
  5. bajansailor
    Re your original idea, do you want to build a skiff in foam sandwich (ie something more like a boat with sides and a cockpit), or do you want to build something more like a foam sandwich paddleboard?
  6. Taylor Waters
    More like a foam sandwich paddle board but have the capability of using a small motor.
  7. fallguy
    Likes: 1,943, Points: 123, Legacy Rep: 10
    I fished from a paddleboard years ago. Things got rough and I tipped over and lost my gear. They were plywood then
