Note: This feature may not be available in some browsers.
I was trying to ask if the foam density was sufficient . I finally was able to figure out that divinycell is about 5lbs/ cu ft. so I was wondering if the 20% decrease in density would be a problem or would the thickness of the core make up for the lower density?.
It can be even worse. When calculating loading conditions, heel due to personnel positioned as far as possible from the center line should be studied, assuming there are 4 people per square meter.Worst pressure of 180 lbs/(3" X 3") (going into English system) your weight divided by the ball of your one foot, with soft shoes on. Not to count the vertical acceleration or running on the deck.
Like somebody wearing high heels.It can be even worse
