DelftShip
seapassionate
Junior Member
Joined
May 22, 2024
Posts
19
Reaction score
Location
Italy
Hi there,
Is anybody who could help me to find out why I cannot get the right side wire frame view while keeping the left side on developable view?
I appreciate any suggestion.
Seapassionate
IIRC there is no such command; whatever you are viewing, it is presented either one-sided or both. You can not have different presentations for two sides.
Thanks Tansl a lot,
glad to see that somebody still on line with DS, unfortunately the original DS forum has been stopped:(
Anyhow in-between I fixed the issue as the other bug which I mentioned in my second post .
Now am facing another problem
all my previous saved files suddenly show this window after first mentioning "couldn't find edge" sometime even showing dark screen!!!
no idea what caused this?!
To be frank I used DS Free for one year or so over 15 years ago, now since then I am trying to get back even if I forgot a lot.
At that time we could get lot of help from the DS forum but now guess only few members are using this one in Boat Design.net
So pretty difficult to progress because bugs are very common all time:(
My only hope is help from somebody experienced in DS like you:)
Seapassionate
I don’t know anything about this software. I consulted an AI, which told me the following:
"The message 'Access violation — EAccessViolation' means that DelftShip has attempted to access an invalid memory location. This generally points to an internal program error; it does not mean that you lack RAM, nor does it mean that you need to run the program as an administrator. Microsoft Learn
The screenshot is from the 64-bit version of DelftShip 18.10 (360), but it does not reveal the exact cause. To help narrow it down:
- If it happens only with one specific project: there may be some data or a geometric element causing the failure.
- If it happens consistently when performing the same operation: it could be a bug in that specific function.
- If it happens when rotating, zooming, or changing the view: you should look into the graphics configuration and the graphics driver.
I would suggest first closing DelftShip, reopening it, and testing a different project—while keeping a backup copy of the one that is causing the error.
Hi Tansl,
Thank you somuch for your time,
Meanwhile DS administrator, likewise, informed me that it is nothing to worry about and sounds some kind of "Emergency backup".
Indeed I can safely delete all my backup fbm files (most probably too many?) to fix the problem.
I do consult AI, which seems to know the commands but useless to fix bugs, sometime it takes hours of wasting time by only Trial&Error which, at the end of the day, doesn't bring anywhere!
Very frustrating not having DS forum anymore:(. It will ,be though! All DS posts on this forum date years back! no much hope to get attention from some DS experts here :(
Thank you again for your kind efforts
Seapassionate
