Delft Systematic Deadrise Series
Discussion in 'Hydrodynamics and Aerodynamics' started by Windvang, Oct 6, 2017.
  1. Windvang
    Likes: 7, Points: 18, Legacy Rep: 65
    Windvang Yacht Designer
    schakel likes this.
  2. Angélique
    The above link gives me this page . . .​
  3. Windvang
    Yes, you need to request a user acount.
  4. Angélique
    OK, thanks . . :)
  5. DCockey
    DCockey Participant
    Thanks for the link. I set up a user account and downloaded the Deadrise Series hull geometries in Rhino format (other formats are available) and complete measurement data.
  6. Windvang
    Do not forget the Papers in the library tab, those will explain a lot.
  7. bit
    Likes: 1, Points: 8, Legacy Rep: 34
    bit Student
    Thanks. Are there B11 and B12 missing?
  8. Windvang
    What do you mean by B11 and B12?
  9. bit
    bit Student
    These two. Thanks.
  10. Windvang
    I did not have a good look myself yet, where are they expected to be?
    I will ask for you.
  11. bit
    bit Student
    Excel:
    FAST 2017 Coeff DSDS twist dRtDepl
    FAST 2017 Coeff DSDS torsione dTheta
    FAST 2017 Coeff DSDS torsione dZNabla
  12. Windvang
    I have contacted them and it will be fixed a.s.a.p. thank you for reporting it.
    If you send me a mail I can send them to you directly.
  13. HJS
    Likes: 139, Points: 43, Legacy Rep: 288
    HJS Member
    I have downloaded and implemented DSDS in my own spreadsheets and tested it with some of my boats. It seems to be a very reliable tool for calculating the performance of my boats over a very large speed range. Thank you for all the information.
    JS
  14. schakel
    Likes: 16, Points: 18, Legacy Rep: 48
    schakel environmental project Msc
    Well I downloaded the whole database and found the hulls tested not so modern.
    Test results are fine, and looks very accurate. Well done.
    Thanks for the link. I can do the same as HJS and make the same calculations on the hulls as proposed by Verdier for the 36th cup. There is only one problem ..
    No-one, except for the Verdier design group, knows how the hulls and appendages will look like.
    I heard the hull looked something like this.
    Source (In dutch):
    Emirates Team New Zealand bevestigt foiling monohull tijdens 36ste America’s Cup | ClubRacer https://www.clubracer.be/2017/9/11/emirates-team-new-zealand-bevestigt-foiling-monohull-tijdens-36ste-americas-cup
  15. HJS
    HJS Member
    Schakel
    DSDS is not applicable to the Verdier boat you refer to. DSDS only fit V-bottom boats. I have now investigated a number of boats and the results are very satisfactory, both calculated and measured. So I can only recommend using DSDS within the limits it is intended for. Your claim that it fits only "not so modern boats" is completely misleading.
    JS
    1. Remmlinger
