Deepsea Challenger burns
Discussion in 'All Things Boats & Boating' started by waikikin, Jul 26, 2015.
  1. waikikin
    waikikin Senior Member
  2. sdowney717
    Likes: 103, Points: 73, Legacy Rep: 274
    sdowney717 Senior Member
    Lithium battery fires, even with sophisticated systems, they burn randomly it seems. Like they go nuclear after a certain set of conditions occurs, and then nothing much except clean up the mess afterwards, the damage is done.
  3. DCockey
    Likes: 666, Points: 113, Legacy Rep: 1485
    DCockey Participant
  4. jehardiman
    Likes: 1,353, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    THEY WERE TRANSPORTING IT OVER THE HIGHWAY ON A LOWBOY WITH THE BATTERIES IN?!?
    <<Facepalm>>
  5. Rurudyne
    Rurudyne Senior Member
    Are you saying that Bill Engvall would present them with their sign?
  6. waikikin
    The reports say that it started with the brakes overeating
  7. sdowney717
    An interesting picture. It is sitting on a flat bed, I suppose the brakes underneath could cause this fire way up on the sub?
    The brakes did not burn the plastic wheel flap nor the tires.
    Maybe so.
    http://www.usnews.com/news/science/...deepsea-challenger-sub-involved-in-truck-fire
  8. waikikin
    Think that wheel/tyre been changed out, there's some other pics with Fire-ies showing flat & cooked tyres. My Dad had an under bonnet brake fluid fire once, put it out before too much damage but certainly scorched the bonnet, seems plausible & the cradle is pictured elsewhere with tyres interfacing the sub in other areas- maybe one of those tyres caught in that area, the web on the uni beam of the cradle adjacent the rear axle shows some scorch as well, tyres love to burn once started.
  9. Kailani
    Likes: 8, Points: 18, Legacy Rep: 59
    Kailani Senior Member
    There's one picture where the trailer deck has been removed over that wheel (clean square removed)
  10. philSweet
    Likes: 582, Points: 113, Legacy Rep: 1082
    philSweet Senior Member
    I'm not sure where you would expect them to put them, but a transport cradle that provided a bit more protection to the battery compartment would have been prudent. I would hope they were mostly discharged; and there should be a battery monitoring mode for transport and storage as well. A transport battery harness with dummy load and safety switch could provide automatic and manual discharge if a hazardous condition was detected. That could all be part of the cradle. Cooling the batteries would also seem prudent. Depends on the type of Lithium battery being used.
  11. daiquiri
    Can't tell whether the Li batteries or brakes are the culprit, but it does look like the biggest damage has occurred where the aft half of the battery pack is placed: http://www.deepseachallenge.com/the-sub/
  12. jehardiman
    Phil....you NEVER transport a DSV with the batteries IN...not Pb-acid, not Ag-Zn, and definitely Li-ion....Its like they have never read anything about highway shock loads...I don't know what to say...
