Mr Efficiency
Senior Member
- Joined
- Oct 17, 2010
- Messages
- 10,374
- Reaction score
- 1,051
- Location
- Australia
Why emphasise speed for such a short hop ? Walking speed will cover 500 metres in 6 minutes.
Note: This feature may not be available in some browsers.
And you want it to plane.
How big of an engine do you have?
How fast is fast enough? 6kts? 20kts?
Will you use a single outboard?
Will it ever carry people? 200KG could take 2 medium sized people.
To size the hulls you will need to know how heavy the boat will be by itself.
You seem to also say it will only operate in fair weather (30 cm)
Will it be controlled line of sight, or will someone have to dock it on the other side.
Will you put the cargo in the hulls or on a deck between them? Next question will be what kind of cargo - feathers or lead weights?
Do you want positive flotation or since you have not mentioned people will it be ok without?
You might look at Richard Woods Powercats.
http://sailingcatamarans.com/index.php/designs/6-powercats/262-skoota-20
Richard has some distinct opinions about efficient hull shapes - I've seen the discussion in his small trimarans section.
You might also look at the W-17 trimaran design, also with a flat bottomed hull - but this is a sailboat. http://www.smalltridesign.com/W17/greybox/W17-Trimaran.html
Sounds like fun project, CpDigriz! Why do you want to use deep vee sponsons?Hello. I have this task of designing a 2mx2mx2.5m dimension catamaran with deep v demi hulls...
Lower deadrise sponsons would have better load-carrying capabilities.Deep v seemed like the best option for increased stability and maneuvering. Flat ones would be kinda bad i think...but im no expert, so...
First figure out what shape will carry your 250kg (with motor?) in the 2 meter length.
I believe it will be quite fat, the deeper the V the fatter and/or deeper.
Deeper means it will not turn easy.
You ought to go for flat bottomed curved up on each end or a round bilged shape (won't carry as much weight for the same width and depth but it should have less drag).
A compromise would be to round the joint at the flat bottom to sides at the ends for less drag than a completely flat bottomed shape.
IMHO
Its never going to plane with as little of a motor as you have.
Again, IMHO.
When does the hull design have to be completed?
