Richard Woods
Woods Designs
- Joined
- Jun 29, 2006
- Messages
- 2,210
- Reaction score
- 178
- Location
- Back full time in the UK
I'm trying to move the discussion on from the concept to details, as they may help other small boat sailors, not just those interested in the "Hardware store" class
And for now I don't want to discuss low cost simple - or even complex - rigs as that is covered in depth elsewhere
Instead I want to start a discussion on making/using simple deck gear, foils etc because I know those are things that get pricey quickly. Good gear makes a boat easier to sail, never mind faster, so it is important to all sailors
The cheapest, simplest option is of course "leave it out". It is also often the fastest
So what controls do you really need? Random thoughts here:
You don't need a main halyard, drawback - you cannot lower/reef the sail at sea. Otherwise it's an advantage. For one thing the main halyard is the most loaded rope on the boat, so is the only one that needs to be high tech. All other control lines can be "hardware store" quality
No halyard can mean no sail track needed. But if you have one on a wood mast what is the best way to make it? RV/caravan awning rail? Slotted aluminium tube bonded on or?
Gooseneck. Make a Laser style one, so just a horizontal bolt, it has the advantage that the mast rotates. Mast step is a 1/2in 12mm bolt embedded in a wood block
Rigging can be simply fitted at the mast end by pushing the wire through the (metal) mast wall and having a nicropress clamp on the inner end, easy to tighten on a household vice as you do it off the boat. Light and low windage
Outhaul. Probably a lashing is good enough for most.
Cunningham - essential but can be continuous rope with eyes tied in, as the Laser used to do. Biggest drawback, apart from friction, is not being able to take controls to the gunwales - or can you?
Kicking strap - also essential. But no need for the ball bearing cascade blocks. Use a lever instead, cheap or free from scrap metal or even plywood, yet very effective for small movements
Rudder fittings are expensive. What's the best way to attach the rudder? Daggerboard style? with a long vertical pin? "Pintles" built into transom and rudder stock - how?
Tiller extension - we've used a telescoping brush handle for years. For shorter extensions plastic water pipe works really well and survives any capsize
Sail battens - we used to use plastic electric conduit - light and cheap but prone to kinking after a capsize
toe straps, old car seat belts from a scrap car
You can get lanyards as tight as a shroud lever, but just not reliably the same setting each time. So good enough for us.
That's enough now, just to get the ball rolling. Any suggestions welcome, but remember they should be useable on a racing dinghy, not a knockabout daysailer.
www.sailingcatamarans.com
