damage stability calculation
Discussion in 'Stability' started by Dr34m3r, Dec 15, 2013.
  1. jehardiman
    Likes: 1,484, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    The D&Os contain moment to trim and moment to heel. For most wall sided "ship shaped" hulls, there is not a significant error of the curves at most trims because of the geometry being limited by the margin line (remember I said computers caused more rigious stability rules, like water on deck). If you decide there is enough flare or tumblehome to make it significant, just lift the correction off the body plan with flimsys and a quick double cross SM.
  2. TANSL
    Likes: 949, Points: 123, Legacy Rep: 300
    Sorry but do not quite understand the indicated phrase.
    Anyway, I think a damage usually produces a significant trim and heel so the position of the center of buoyancy and the center of gravity of the waterplane can vary greatly. The area of ​​the waterplane is complicated to calculate and the value of its moment of inertia, around an axis passing through, don´t forget, the new center of gravity, changes a lot. Therefore, an estimate of the metacentre seems very inaccurate and, therefore, the calculation of GZ values can be not aceptable = equilibrium floatation difficult to determine.
  3. Dr34m3r
    Likes: 4, Points: 18, Legacy Rep: 10
    Dr34m3r Senior Member
    GZ Curve
    I am wondering when the GZ value will be negative,
    following the example attached, if angle = 85 then GZ = 135 (!!) ?
    when the GZ value will be negative ?
    Can get my mistake of understanding ?
  4. jehardiman
    If you have much experience pulling data from a set of lines and know parallel axis concepts it is neither time consuming nor difficult and as I said, the forms are standardized. Again, you seem to think computational difficulty = better accuracy, which is not the case.
    You are trying to use wall sided small angle theory for damaged stability, which will not work. GZ is a function of GM for only small angles of heel, for large angles, especially in the damaged condition, you need to calculate GZ from CG and CB. Make sure you understand this difference. Go see these old threads (and ignore the scarcasm in the second one.)
    http://www.boatdesign.net/forums/stability/metacentric-height-27171.html
    http://www.boatdesign.net/forums/boat-building/calculation-gm-8852.html#post60405
  5. Dr34m3r
    Thanks jehardiman !
    It seems like nearly huge work for by hand calculation to get the GZ in damaged condition ? I have found some reference in Attowd's book but complicated.
    Is there any other reference available to understand by sample calculation for GZ (damage condition ) ?
  6. TANSL
    Jehardiman, probably I'm not getting anything but I do not know where are these so standardized forms such as when a damage as in attached picture occurs.
    And of course, take easurements with a computer is much more accurate than extracting data from a drawing on paper. Don´t know if you mean it or not.
    I know Steiner's theorem but the difficulty is not to draw an axis parallel to the centerline but find the point at which we must draw this parallel axis.
    But the important thing now is to explain CB Dr34m3r how to calculate BM using Bonjean values.
  7. Dr34m3r
    yah. still not clear about getting GZ in damaged condition. No single formula for it , i was following added weight method ?
  8. Ad Hoc
    Hmmm
    Ok, so the whole methodology and procedure has been outlined already on this thread by several posters, notably JEH; all telling you it is not a single formula procedure.
    So, looking at the steps one must take, from JEH, looking at the first iteration:
    Can you post your calculated volume for the damage void 7P?
  9. Dr34m3r
    volume
    Calculated damage volume is like the picture attached . ( as i only have the images of the plan not actual cad files, so i am not worried about the value but emphasizing the procedure of calculation )
  10. TANSL
    Do you have to study the simultaneous flooding of two compartments?
  11. Dr34m3r
    yes, assuming, both flooded at the same time.
  12. TANSL
    That is a very restrictive condition that, even for passenger ships, is not normal to have to study. Is your boat a type that force you to study two compartments?
  13. Dr34m3r
    This is not a passenger ship , if you look at the plan. I have to test the case to damage in two compartments.
  14. athvas
    Likes: 1, Points: 0, Legacy Rep: 16
    athvas Senior Member
    Your Resultant Displ would be 20532.56 Tons. Correspondingly your lcg , tcg , vcg values to change.
    Lcb, lcg values from which reference ? from aft ? . You have mention vcg of Hull as 18.349 ... How it could be ?... It seems too large
  15. TANSL
    I know that some people will say that is nonsense what I say but my advice is to get a good naval architecture software and to use it for your boat. Later, or at the same time, make assumption of what and how you would have to do to calculate it by hand. In my opinion it is not a case that can be learned from this forum. You need some expert close to you, advising you, checking your progress, and explaining the concepts and procedures that must be employed.
    Sorry, me at least, I feel myself unable to guide you along this path.
    Cheers
