daggerboat area
Discussion in 'Multihulls' started by Gianf1041, Apr 18, 2019.
  1. Gianf1041
    Likes: 6, Points: 8
    Gianf1041 Junior Member
    a question: what percentage must have the area of the catamaran centerboard compared to the sail surface?
  2. jehardiman
    Likes: 1,501, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    For a well designed hull you don't need a centerboard. What is the hull section shape?...U or V ?
  3. Gianf1041
    Likes: 6, Points: 8
    Trasversal section.......!
  4. Doug Halsey
    Likes: 218, Points: 53, Legacy Rep: 160
    Doug Halsey Senior Member
    You trying to pick a fight?
    Dejay likes this.
  5. Gianf1041
    Likes: 6, Points: 8
    I apologize but I didn't understand the meaning?
  6. Doug Halsey
    My comment was directed at Jehardiman, not you. I think quite a few would disagree with what he wrote.
  7. Gianf1041
    Likes: 6, Points: 8
    ok, no problem, ........... sometimes I have difficulty understanding the translation from English to Italian.
  8. Gianf1041
    Likes: 6, Points: 8
    however my question was on the percentage to be assigned to the surface of the drift with respect to the sail surface ..........: between 6% - 10%, ........... ratio centerboard surface - sail surface ... 0.015 - 0.025 ..... ??? are they correct parameters ???
  9. bruceb
    Likes: 59, Points: 48, Legacy Rep: 214
    bruceb Senior Member
    Gianf, on the smaller cat's and tri's I am used to, a board area of about 2% of windward sail area would be a starting point, at least a guide line. That is assuming a well designed high aspect board, 4:1 or longer. Faster boats boats might need less. I am using a 1.7 % area board on my old medium performance 33' tri with good results.
    B
    Doug Lord likes this.
    1. Andrea Wasserliebend
    2. Brorsan
