Alan Cattelliot
Senior Member
- Joined
- Jul 6, 2021
- Posts
- 524
- Reaction score
- 220
- Location
- La Rochelle (Fr)
I really like to know how your trials will go. Thanks for the compliment, Serdar
Note: This feature may not be available in some browsers.
None of that is to claim that flat boards are as good as perfect foil sectioned ones. But the difference is not all that big and does not matter very much for a casual sailor.
Serdar you have gotten some very good information from several of our knowledgeable members. I will stick my oar in with some less sophisticated, but still practical, comments.
You have said that you are not a racer. I do not know what sort of dinghy that you have. If it is a hot rod like say...an RS Aero then, then you would probably want a sophisticated board and rudder. But what if you are never going to compete in fleet racing? If you have a simple dink that is intended for fun sailing, then don't sweat the board. A simple flat plate will work pretty well if it has only a little bit of help on the leading and trailing edge. No need for sophisticated foil sections. I am thinking of the Windmill class boat. Class rules specify that the board be three quarters thick and have the leading edge beveled at no more than one and one half inch back from the LE. The same specification for the trailing edge. Same deal for the rudder. I promise you That a well sailed, and properly rigged, Windmill will go to windward very efficiently. As high and as fast as some very fancy boats with more sophisticated foils.
None of that is to claim that flat boards are as good as perfect foil sectioned ones. But the difference is not all that big and does not matter very much for a casual sailor. You have mentioned the L/D ratio of a section at 16 to 26 degrees. I suspect that the foil will be stalled well before any of those incidence angles come into play. As for the trialing edge. a blunt edge of 2 or 3 mm ain't gonna matter enough to measure with seat of the pants data input. One of the more important design features is size. Make the board bigger than you think it needs to be. A bigger board makes a happier skipper when sailing in light airs.
