From
Aluminum Temper Designations: How do They Work? - Gabrian https://www.gabrian.com/aluminum-temper/
The statement contained within this article : First, consider that certain aluminum alloy series can only be strain hardened or thermally treated, which may limit the number of choices you have in manufacturing. Wrought aluminum alloys 1XXX, 3XXX, and 5XXX non-heat-treatable, while alloys 2XXX, 6XXX, and 7XXX are heat treatable. Some 4XXX series wrought aluminum alloys are heat treatable, while others are not.
Assume that you are referring to sheet/plate profiles. Most boat builders use the 5XXX series for plating a boat. ( and more often than not, 6XXX for extrusions)
As 5XXX series are not heat treatable, I cannot see any reason why a laser cutter would impart characteristics that would ""create a form of heat treatment for the edges and then you don't get good welds""
Can you get your "someone who should know" to offer an explanation for this statement?
The fibre optic lasers that I have seen demo'd at Fabtech are faster than say a plasma table. So I suspect that the HAZ width may be less, but then as you weld up the joints, the aluminum will be exposed to more heat than the actual cutting process. The material has to reach a certain temperature to melt and it is quite low as compared to steel.
Was there any chance that he was referring to steel? Generally, high carbon steel is heat treatable but in its
simplest process, the steel is heated, then quenched to increase strength. As there would not be a dedicated quench in the laser cutting system to "harden" the material, it is unlikely the high temp cut zone would harden.
I guess the question would be this: Would the cool surrounding material self quench the thin laser kerf line?
