Now that my custom DIY designed and built extended swim platform is in use, I thought I would just summarize this journey . . .
I've had an extended swim platform on my boat 'bucket list' for quite a few years and finally decided to do it.
It started in August 2018 with an idea and some basic measurements . . .
I started with a rough foam board structure of the platform, which would become the 'plug' for making a mold.
As I worked the foam structure, I enhanced the design a bit . . .
I got lots of input along the way.
One of the key points was when I contacted Formula (boat manufacturer) about how they do their extended platforms, and got some great insight, encouragement, and pictures. This helped me refine and greatly simplify the attachment design.
I tried infusion molding for the first time, which proved to have a fairly steep learning curve; more so than other boat building and restoration projects that I have done in the past.
I finished the 'plug', then made the mold from the plug. Then I made the actual swim platform from the mold.
10 months after starting (August 2018 -> June 2019), working 1-2 weekends a month, this was the final outcome.
Overall, I'm quite satisfied with the results, having achieved my objectives.
My main reason for doing the 3-steps of plug-mold-part was to get a nice, factory-like non-skid surface in the gelcoat. My rationale for doing infusion molding was to achieve good strength to weight. I think my final weight of the platform with all of the hardware and struts ended up being about 135 lbs.
If I had to do it again, I might opt for a fiberglass over foam approach. . . but maybe infusion would be easier the second time around. . . not sure.
Anyway, I hope this thread will be useful to others who may be contemplating a similar project on their boat.
