Northeaster
Senior Member
- Joined
- Sep 18, 2011
- Posts
- 265
- Reaction score
- Location
- Eastern Canada
Tonight I tried a new loaner aftermarket temperature gauge, directly off the sensor, to compare with my gauge. But, the sensor has two leads and this gauge only had pos, neg and S - I assume for sensor. It seemed to work as it gradually rose but must not have been calibrated, or I did not have to connected correctly, as it started around 150F, and finished at 260F or so, whereas my gauge started at below 100F and topped at 210F - when I shut the engine off. I did not connect both gauges to the sensor at the same time, just one at a time and switched the wires to compare.
So, still not sure if my gauge works properly, but I believe it is more accurate than these false high readings- as it certainly wasn't 160F to start - engine was cool, say 75F.
One note though, as it was warming up, we got much more consistent bursts of warm seawater exiting and my temp gauge seemed to go up a bit, then stay there or cool a bit as the seawater took heat away, then seawater would go cold, temps would rise a few degrees, and the seawater warm again, temps drop a bit, and so on. This cycle went on a few times till it got around 200 - 210 so I shut it off.
As Baeckmo has mentioned I should have much more seawater flow (ie 20 gpm) I will likely break down and buy the proper gear driven Cummins / Sherwood m71 seawater pump. This electric setup was really just to sea trial and sea how the new boat performed. I am happy with the 23 kts hit so far, and the handling, so I can now justify making a bit more investment...buying the proper pump and doing more sea trials before continuing finish work this winter.
I don't understand though, if I was at 190F - 200F for more than 5 min or so, why was the thermostat not open more often / longer so it could circulate more hot coolant to the heat exchanger, more frequently?? seems to me the seawater flow would have been able to take away more heat, as I had cycles of perhaps 30 seconds or 1 minute of cold water exiting before say 30 seconds or a minute of hot water..
Anyway, I will likely get the proper pump and sea if that fixes things, or just rules out one more, expensive....thing..
