Something I sort of have an issue with
A traditional cat hull is wider on the waterline but draws less
CS hull shape is narrower on the water but draws more
Wouldn't/couldn't wetted surface area work out similar?
Hi,
Is this section back at the stern? If yes the boxy part of the boat is under the waterline. (I would like to know how much should normally be). Now, I believe even if the drag is the same with a similar boat, the boxy flat part aft helps to give some lift when the vessel enters in semi-planning mode, otherwise it will never plan. The rest of the Canoe shape behaves at low speeds as a displacement vessel with low drag. Am I correct?
Anout CS there was an article of Noah Thompson Design (New Zealand) which I reproduce here:
By: Noah Thompson
Fuel efficiency starts at the hull.
Over the last few years I have been working on developing my own in-house hull testing procedures. Part of the process involves using the most up-to-date computer programs and also some programs I have developed myself over that time. As always, these are just prediction programs and are subject to many variations and analytical equations. The results will vary so I use a control hull to calibrate the programs when testing new hull shapes. The control hull is one that is already in the water with proven performance numbers. When comparing the new hulls in the program, I am able to see if there is a problem with the program or 3D model by running my control hull through it simultaneously. If the numbers are too far from the truth, I go back and refine the hull model until the programs start producing what looks to be “real world” numbers to me.
Almost all of my work consists of designing custom vessels. Therefore each vessel is unique, and all of them have very different requirements. Some of the vessels will be required to go fast, and others will be designed for the best possible fuel efficiency at cruise RPMs of the chosen engine model. So for every vessel I design I need to develop the hull shape to suit those requirements and displacement. One hull “shoe” does not fit all, in my case.
To demonstrate my point: I have a customer asking for a 12m sport-fishing catamaran. The cat will weigh in around 7.2 ton. They would like to cruise at 20 knots with a top speed of around 26 knots with the best possible fuel economy. As many would think, a CS displacement hull would be the most suitable for the fuel efficiency aspect, and a planing hull would offer the highest top speed. I developed 3 rough models and ran them all through my speed prediction programs.
Planing Hull. This is a semi asymmetric hull shape with a 28-degree deadrise. It has long planing surface area and will get up on the plane around 12 –14 knots. The asymmetric shape helps reduce wave interaction in the tunnel area reducing noise and also resistance from wave interaction. The hulls are wide and offer good internal accommodation space. They are also very easy and cost effective to build from a flat panel kitset.
Semi-Displacement. This is a wide body hull form. It uses width for buoyancy and offers really excellent internal accommodation. Over the years I have modified the front of the hull into what I call “Torpedo Noses”. The torpedo helps the hull shape in three ways. First it offers a longer water line length for the vessel. Second it offers a better forward prismatic coefficient for the hulls, allowing a smoother water flow over the wide body section of the hull. Third, it offers increased forward buoyancy to the hull. This allows the hulls to cut through a wave cleanly, but also rising up with buoyancy in the wave before the wave impacts the tunnel and creates a slam.
CS Displacement Hull. This is a slender body canoe stern shape. It has a fine water entry and a box aft to add extra buoyancy. At displacement speeds, it is an efficient hull form. However the narrow waterline greatly reduces internal accommodation space. The slender hull forward makes this hull form susceptible to tunnel slamming, as there is not enough buoyancy forward to carry the hull out of a wave before it impacts with the tunnel. The hull relies on depth rather than width for its buoyancy.
I ran the three test models through my velocity prediction program to see how each would perform at 20 knots cruise speed and 26 knots top speed. I used a displacement of 7.2 ton for the predictions.
Planing Catamaran Hull (Green)
@ 20 knots requires 327 hp
@ 26 knots requires 527 hp
Semi Displacement Catamaran Hull – (Blue)
@ 20 knots requires 246 hp
@ 26 knots requires 450 hp
CS Displacement Catamaran Hull (Red)
@ 20 knots requires 207 hp
The hull speed tops out a 24 knots and requires 330 hp
The numbers show that fuel efficiency starts with the right hull design. If you’re thinking about a new boat, it is worth considering the effects of the hull shape early on in the design process. After making the right hull selection for your application, it is a matter of engine comparison to suit the hull shape to maximize efficiency. But that may be an article for another day.
By: Noah Thompson.
http://www.noahthompsondesign.com/
Written for Multihull World 2010
Above Blue Green and red in the text refers to some Hull pictures which I do not have. You may contact N. Thompson to learn more details.
A serious remark of him for CS is also :
Regards
APP
