Note: This feature may not be available in some browsers.
Is this a solo endeavour or will there be capable assistance? On a 45 foot solid timber sailing houseboat everything you handle is heavy, bulky and dangerous, plus mentioned open water passages are Russian roulette.
Have a look at Richard Woods Gypsy (or other models of sailing catamarans around 30' long), loads of space for a couple, capable of ocean crossings, can be beached for maintenance and can be disassembled and trailed. More importantly, it is easily handled solo.
Sailing Catamarans - Gypsy - 8.5m Budget Offshore Cruiser with central cuddy https://sailingcatamarans.com/index.php/designs-2/3-25ft-to-30ft-catamarans-designs/176-gypsy
A well travelled and highly modified Gypsy:
Light Wave – 28 then 32 37 foot Catamaran – Time For a Catamaran Adventure https://www.time-for-a-catamaran-adventure.com/light-wave-woods-32-37-sailing-catamaran/
Scow for a more basic catamaran style check the Wharrams. The term "Wharram custom innovations" is not always considered in a favourable light. Some are great, and some more about marketing hype.Thanks for the examples - I’ll take a look. I could probably limit single-handed use to motor cruising, but what you’ve discussed I need to give more serious consideration to.
Tiki 38 - James Wharram Designs https://www.wharram.com/gallery/tiki-designs/tiki38
There is also a free set of rough plans being touted, but would suggest very much "buyer beware".
The $21K catamaran: Build a cat fast and cheap https://www.thecoastalpassage.com/cheapcat.html
I think you should take a good look at Oddity, a yacht that's built to do the same things you think you want to do. No, she's not cross planked she's plywood and the bottom has a 3/8" steel plate to protect it when she takes the ground, a feature I highly recommend.
