I would like to build myself or contract with someone to build a wooden, shallow draft workboat hull with LOA LxW dimensions of roughly 49’x16’. Intended use is as a platform on which to construct appropriate weight and height cabins and pilothouse out of lightweight materials to create a “houseboat” with more seaworthiness than the typical box-on-pontoons approach as well as being able to walk safely around the perimeter. Slow, deliberate voyaging in rivers, bays and occasional coastal stretches and modest crossings are the hope, with willingness to delay frequently for good weather. A combo of outboard motors and simple sail plan for propulsion. I’m picturing a design with no decks or minimal decks, but that’s really only because I’ve thought I’d like to have free access to the bottom hull planks for regular oiling and inspection. A cross planked bottom appeals to me for it’s construction simplicity and as I think it looks appropriate to a simple workboat hull. I have three primary questions for those knowledgeable of cross planked construction and/or use of boats with same: (1) is it reasonable to use cross-planking where the boat width would require planks this long (i.e., 15’ mol)? (2) if so, can you speculate as to an appropriate type of wood and thickness? (3) might there actually be any advantage to a deckless design for regular inspection and oiling of bottom planks from the interior or is that a dumb idea? Thank you very much for your consideration.
