cross galvanic corrosion?
Discussion in 'Boat Design' started by Cmw505, Aug 20, 2019.
  1. Cmw505
    Likes: 1, Points: 8
    Cmw505 Junior Member
    So just a quick question..if two different hulls in the same marine close to each other let's say one made of alumnium and the other steel what exactly stops these hulls from interacting with each other so close by? thanks
  2. Heimfried
    Likes: 153, Points: 43, Legacy Rep: 37
    Heimfried Senior Member
    To build up a galvanic current circuit there must be a electroconductive link between the hulls (a second link besides the water). This can happen indirectly if both boats are connected to onshore grid ground. To prevent this the market offers galvanic separators.
  3. Cmw505
    Likes: 1, Points: 8
    thanks heimfried
  4. JSL
    JSL Senior Member
    I thinks these are same as isolation transformers
  5. MikeJohns
    Likes: 209, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
    An isolating transformer without the earth connected thru would do it but it's a heavy expensive option .
    Galvanic isolators are installed in the Earth line only and interrupt continuous dc currents while still passing AC fault currents. They are a much more sensible solution.
  6. Cmw505
    Likes: 1, Points: 8
    i was just curious cause as i'm studying boat design and hulls,and materials etc. i started to learn about sacrificial anodes and it got me thinking with boats so close together in the marina how on earth do they not interact assuming that there moored to the dock?. but heimfried just explained that.
