Hello, I appreciate the board. I'm an aircraft guy and I am trying to do the impossible. I have Craigcats and I live in the Florida Keys. A billion square miles of water and most of it is 15". So my impossible goal is for the boat is to draft 12". Here is the issue, it has Evinrude ETec 30 horse engines, by design the anti cavitation plate is 5 to 7 inches below the bottom plane of the pontoons this gives me 18" of draft and even when the pontoons are on plane, the engine plows the water creating much drag and down force on the bow.After much discussion with various boat professionals I feel this is to keep the boat slow, stable and safe. Sadly it conflicts with my need of a 12" draft. Although the boats are thought to go 30 Mph, I have only had them go 26 top speed. For the shallow version I want, speed is not the goal, so even 10-15 MPH would be fine. ( Backwater Tours type thing ) I have considered raising the engine to put the anti cavitation plate just below the bottom of the pontoon, this might give me a draft of 12 to 14" I have considered a smaller outboard, and modifying the mount plate to have the propeller as high as possible between the pontoons, obviously requiring a rudder system similar to a Sea Plane, however I could create it using the same steering arm the boat comes with. I have might give me 6 to 8"searched for an inexpensive surface drive prop system, which might give me a 6 to 8" draft. I have also considered adapting a Waverunner drivetrain/Jet Drive to the boat with would probably give me a 4 to 6 inch draft. The boat floats as is in 4 inches of water. The knowledge I lack is fluid dynamics and how the pontoons displace water, at what rate vs the requirements of the throughput of water volume to propel the boat. Anyhow I know of you guys are professionals and this probably sounds like idiocy to you. I have been an aircraft tech for 37 years and am also a structures/composites person, so I am not totally clueless. For the record, as sold these boats are terrific, every customer we have had LOVE them. I simply need to make one run as shallow as humanly possible. Thank you
Steve
Steve
